jet fuel type a?
Old Feb 21, 2009 | 11:40 AM
vu337's Avatar
Default jet fuel type a?
can i mix gasoline with jet fuel type a? my car was tune with q16 race gas
Old Feb 21, 2009 | 11:43 AM
rota92
Guest
Posts: n/a
Default Re: jet fuel type a?
Yea you can mix it.
Now, would you like to know if it will work or not? lol If it was tuned on Q16, run Q16.
Old Feb 21, 2009 | 11:53 AM
Bigblockhatch's Avatar
No you cant.......Jet a is and i qoute for you "Kerosene-type jet fuel (including Jet A and Jet A-1) has a carbon number distribution between about 8 and 16 carbon numbers; wide-cut or naphtha-type jet fuel (including Jet B), between about 5 and 15 carbon numbers.[2]"
Old Feb 21, 2009 | 11:55 AM
vu337's Avatar
i got some jet fuel avaiable i just wanted to know if anyone knows the amount to mix
Old Feb 21, 2009 | 12:00 PM
rota92
Guest
Posts: n/a
I think you missed my sarcasm lol You can mix anything, whether it ends up homogeneous or heterogeneous it's still doable
And OP, don't even try it. Just keep the Q16 in it, it's made to run in a vehicle. We all have access to crack, but you don't see us all using it do ya?
Old Feb 21, 2009 | 12:01 PM
Redline130's Avatar
I wouldn't even consider using it. Just use what your car was tuned on, in this case Q16. It's just not worth the risk of the potential damage you could do to your motor.
Old Feb 21, 2009 | 12:52 PM
V-SPEC 1's Avatar
What about AV gas or aviation 100 leaded octane can I mix that w/ 93 unleaded octone? the car has not been tune on any race fuel yet but we are about to street tune one tonight and I just want to know if its safe to use this gas on say 15-20 psi of boost. Thank you all.
Old Feb 21, 2009 | 01:10 PM
rota92
Guest
Posts: n/a
If you're gonna tune it as a street tune I take it it's a street car?
Just run pump since I would imagine that's what most cars would run anyways.
Old Feb 21, 2009 | 01:15 PM
boostfeen's Avatar
lol, why would you even ask a question like that Do yourself a favor and stick with the q16. If you have a little extra Jet A, save it for your floor bullet heater
Old Feb 21, 2009 | 01:18 PM
boostfeen's Avatar
..exactly. ..and if you have a cat, the avgas will kill that, and you will end up fouling out your plugs sooner or later too
Old Feb 21, 2009 | 01:55 PM
SpeedDreamz.com's Avatar
IF you didnt want to buy q16 then you should not have used it for your tune. Tune it on what you can run and run it on what you tune.
Old Feb 21, 2009 | 04:18 PM
vu337's Avatar
hey guys i was just wondering because i got 2 qts. of jet fuel, that's why i asked if i can used it , but if u think i need to stay t q16 i will definitely will
Old Feb 21, 2009 | 05:07 PM
jjspec's Avatar
DO NOT MIX THE JET FUEL!!! It is more related to diesel than to gasoline. It is like a higher grade kerosene. Like someone else said, put it in your floor bullet heater and enjoy!
Old Feb 21, 2009 | 05:33 PM
Drew Peacock's Avatar
Yeah it staves of detonation quite well.
Old Feb 22, 2009 | 08:35 PM
V-SPEC 1's Avatar
thank you
Old Feb 22, 2009 | 08:40 PM
InDub's Avatar
LOL
Old Feb 22, 2009 | 10:25 PM
streetracer6rpt's Avatar
listen 2 the man who puts C16 in a generator, kaboom..
lol
Old Feb 23, 2009 | 04:30 AM
redzcstandardhatch's Avatar
something different
aviation gas is fine, if you wanna deal with the side-effects of leaded gas, but Jet fuel IS NOT A GASOLINE PRODUCT.
you'd be better off putting Coleman Lantern oil in the gas tank.
Old Feb 23, 2009 | 09:36 AM
vu337's Avatar
thanks for all the info guys!
91CivicEF
Jan 20, 2009 12:05 AM
felipe69
Mar 21, 2008 08:53 PM
accordselux
83
Apr 12, 2006 02:04 PM
carbonall
51
Jan 6, 2006 01:19 PM
JDMTurboEG6
Nov 11, 2004 11:11 PM
