Blown headgasket
Other than a loss of coolant which will eventually lead 2 overheating are there any other symtoms that may help diagnose a blown headgasket? Also my head has a slight tapping and the engine seems to be burning more oil, not sure if the rings are damaged also.
There is another easy way to check if the headgasket is blown. U just need to open the radiator cap, and fill up coolant, then start the engine. If U see the coolant is push out of the radiator quickly and a lot, that means your headgasket is blown.
Another way to make sure the headgasket is blown is doing compressor test. But U can try the easy way first. Good luck!
if you think your rings are shot then it would be blue smoke.
if you think its both, drain your oil. coolant should settle on top.
A Tribe Called Honda
Feb 21, 2008 03:19 PM
