Common oil leak on 2000 GSR?
Old Feb 21, 2009 | 09:58 AM
dc21989's Avatar
Default Common oil leak on 2000 GSR?
So I have finally got sick of my integra leaking even though it's a minor leak. I know that the cam seal tend to leak oil on these engines but Ive checked and I didn't see and sort of leaking. Do you guys think it could be the oil drain plug or the oil pan gasket?
Old Feb 21, 2009 | 10:07 AM
milo-gsr's Avatar
Default Re: Common oil leak on 2000 GSR?
Clean around your oil pan and see if it leaks there. If its not then it could be coming from the back of the block between the oil filter and the block. I think its called the oil cooler gasket. How much miles do you have on your motor?
Old Feb 21, 2009 | 10:11 AM
dc21989's Avatar
around 114K
Old Feb 21, 2009 | 01:00 PM
racebum's Avatar
no oil cooler on the 96+ gsr. pan gaskets are common leaks however. they get very brittle with age.
Old Feb 21, 2009 | 02:09 PM
dc21989's Avatar
Would it be hard to replace the oil pan gasket? I know a torque wrench would have to be used
Old Feb 21, 2009 | 02:23 PM
delbert's Avatar
my oil pan gasket is leaking for a fact i know that its oily down there.
Old Feb 21, 2009 | 06:52 PM
racebum's Avatar
it actually doesn't but it might not hurt if you aren't use to the feel of how tight it needs to be. the important thing is to step it in. tighten all lightly then inside out for the final torque. two stages is smart. also buy a honda replacement gasket. the felpros are similar but seem to leak easier.
johnny_bighood
21
Jul 4, 2009 02:03 PM
Teglessb18
Oct 21, 2005 03:06 PM
Mattyg2
Aug 28, 2004 04:50 PM
Pinhead
Jun 9, 2002 01:53 PM
jwiedmayer
Nov 30, 2001 07:02 AM
