Bad fume from header area.
Old Feb 21, 2009 | 08:29 AM
db8int3gra's Avatar
Default Bad fume from header area.
What can it be. I start noticing a kind of bad fume from my header area. It smells like those old 80's cars with the bad exhaust smell that pollutes the air. It doesn'r smell horrible but after a drive and I open my hood I start smelling it. My question is....what can be the problem.......do I need a new o2 sensor or do I have a bad seal. I don't know.
Old Feb 21, 2009 | 08:30 AM
james_ls's Avatar
Default Re: Bad fume from header area.
Where in the "header area" is this smell coming from?
Do you have a blatant exhaust leak somewhere?
Still have a CAT?
Old Feb 21, 2009 | 08:32 AM
Former User's Avatar
Sounds like a leak in the exhaust manifold causing the engine to run rich.
Old Feb 21, 2009 | 09:04 AM
db8int3gra's Avatar
Header area.....just right between the valve cover and the header shield. I haven't notice my engine running rich by the way. yes, I still have a cat.
Old Feb 21, 2009 | 09:11 AM
Targa250R's Avatar
be professional
Cracked manifold, rotted pipe, or leaky gasket.
Doesn't sound like you really know what you're looking at, so you should probably take it to a professional.
Old Feb 21, 2009 | 09:59 AM
DB8_LSVTEC's Avatar
check the gasket on your header.
moonchies
Aug 9, 2018 10:54 AM
Extreez
Jan 24, 2007 03:28 PM
stiness101
Jan 11, 2006 10:12 AM
976
Aug 20, 2004 10:26 AM
robbieshonda
Mar 4, 2003 04:33 PM
