Throttle body question
I have a built LSV running pro 1's. I have a skunk2 pro series intake manifold. Is there a benefit with having a larger throttle body. LIke a 70mm over a 68mm? I figure bigger is better..more air=more power. But are there cons to having a 70mm over a 68mm?
Its just over 12.5:1. Ive talked to king motorsports and they suggested a 68mm so Thats what Ill prolly go with. It has to be better then the stock gsr one. HA! But I would like more explination on why well...if someone uses the more air is better theory...why not getting the larger throttle body is always better? I have heard several things but I'd like a better explianation
The engine dictates airflow, not the throttle body diameter. If nothing else is changed, a larger diameter will make the throttle more sensitive, and maximum flow will be reached earlier. In this case, any pedal travel after this point is useless.
GSlowR
20
Jul 5, 2003 03:26 AM
