90 si d16a6 swap into an 89 dx
So I found an si hatch at a junkyard that has a d16a6 and I'm thinkin of getting it however I have a couple questions.
How much are those things worth nowadays?
I was thinkin about offerin him 100 for the engine.
The odometer reads 220k.
And also, the engine is from a 90 si, and my car is an 89, is that gonna matter as far as the wiring goes in my car?
I'd appreciate any advice. Thanks.
it will bolt in, you will need that engine harness to use the injector harness etc, but you will ultimatly use your existing harness modded with the si one, search mpfi or check the faqs, you will also need the ecu to go with the engine. if yours is a 5 speed make sure to get the 5 speed ecu or you will get the trans convertor code.
uptownx24x
10
Jun 20, 2011 07:17 AM
uboostivtec
Sep 10, 2009 10:12 AM
jdm_ef9
Jul 3, 2002 06:55 AM
