FS MAKE OFFER: ECU Tuning Engine Block K20A Intake Climate Interior Parts
OBD1 Socketed / Chipped VTEC ECU
This is a socketed, chipped and ready to tune VTEC ECU for your B-Series or D-Series engine. Compatible with ROM Editors such as Crome, Uberdata, Hondata, eCtune, etc. This complete ECU includes a ZIF socket, Reburnable Chip, and the 4-pin header for datalogging. If you give me your naturally aspirated engine combination i can burn a custom or virgin Honda map to the chip. Or you can have your Engine Tuned + Chipped VTEC ECU (see link in sig). Has also been tried and tested.
$135
MAKE OFFER
K20A / K-SERIES INTAKE / i-VTEC COVER
OEM Intake Tube w/ Air Box
- OEM mounting hardware included
i-VTEC cover
D15Z1 Long Block VIN# 2HGEH2361NH509061 **MAKE OFFER**
This is a VTEC-E engine. Has 240k miles on it and is from a Civic VX.
PARTS SOLD:
crank pulley
upper / lower timing covers
driver mount + post mount
Comes with:
-all sensors (except Purge Cut Solenoid has a broken port)
-distributor
-spark plug wires
-fuel rail, injectors, fpr
-map
-tps
Needs:
rebuild
clutch (i can supply new per request)
oil pan
VTEC Water Pump (90k miles)
GSR Radiator (80k) miles)
1994 GSR short block VIN JH4DC2381RS004564
It is bare.
It has some flaws listed below that can be fixed.
Stock 81mm bore, with 90k miles on it.
Nick on water jacket side
Grazed water pump mounting hole + 2 stripped driver side mount holes
3 inch Flex Pipe
D-Series OEM Flywheel
-200k miles
-needs resurfacing
GSR OEM Flywheel
-90k miles
-needs resurfacing
GSR AC Compressor
GSR Blower Fan
GSR Condensor
GSR Heater Core
MOUNT / BRACKET
$$MAKE OFFER$$
Thermo Housing w/ Cover + Thermostat
Connecting Pipe
GSR Water Neck
GSR Power Steering Pump (80k miles)
B16 / LS Oil Pick-up / Strainer
B16 / LS Windage Tray (small gash), was used on 600hp turbo
Fast Idle Valve
GSR Brake Master Cylinder (80k miles)
$$MAKE OFFER$$
GSR Guage Visor Dash Trim
GSR Turn Signal Switch Mechanism
GSR Door Handles
GSR Dimmer Switch
GSR Cruise Button
GSR Cruise Control Module
Located in central jersey. Ship cheap UPS ground. Paypal Verified. Please PM / E-mail me.
Thanks
i.
$135
MAKE OFFER
i-VTEC cover
PARTS SOLD:
crank pulley
Comes with:
-distributor
-spark plug wires
-map
-tps
Needs:
rebuild
oil pan
It is bare.
3 inch Flex Pipe
-200k miles
-needs resurfacing
GSR OEM Flywheel
-90k miles
-needs resurfacing
GSR AC Compressor
GSR Blower Fan
GSR Condensor
GSR Heater Core
MOUNT / BRACKET
$$MAKE OFFER$$
Connecting Pipe
GSR Water Neck
Fast Idle Valve
$$MAKE OFFER$$
GSR Door Handles
GSR Dimmer Switch
GSR Cruise Button
Thanks
i.
Central Jersey.
since your pm is turned off, my e-mail address is on the site in my sig.
i.
i.
JerseySiPOS
Northeast (Sales)
Apr 19, 2010 08:07 PM
JerseySiPOS
Mar 1, 2009 07:42 PM
