Help me!!
Old Feb 21, 2009 | 12:40 AM
SeanWard's Avatar
Default Help me!!
my mpfi swap is complete, but it wont start. when we spray ether it will starty. the car is getting fuel and the injectors are pulsing. what shoud i do????
Old Feb 21, 2009 | 01:26 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Help me!!
Check for spark.
Double,triple,... check wiring.
Check wiring again.
.. and again.
Then make sure your wiring is correct.
Old Feb 21, 2009 | 02:10 PM
DazeMS's Avatar
CHECK ALL grounds, and make sure to add a few more as well! make sure the ecu is being grounded properly.. Sounds like spark is not adequate.
Old Feb 21, 2009 | 04:09 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Well remember this... your spark and timing are probably fine, the only reason that your car would start with ether and not start without it is because it is NOT getting fuel. Get a noid light or do it the caveman way with a multi-meter and check to see if the injectors are actually getting voltage and firing.
Also if you use too much ether tends to foul plugs if too much is used. This could also lead to a no start problem.
If the car starts then you have spark.
If the car starts and runs normal the timing is around correct.
If the car turns over slow and the battery is good then the timing is too advanced.
bestcivic
Aug 11, 2009 08:20 AM
crave13k
Honda S2000
32
Mar 17, 2009 09:37 AM
honduh8993
May 5, 2007 09:56 PM
oOPreludeBoyOo
Jul 20, 2003 08:11 AM
johnjohn410
Dec 17, 2002 10:21 PM
