b18a1 in 91 hatch dpfi to mpfi ISSUES omg
Old Feb 20, 2009 | 11:30 PM
ef_b18a1's Avatar
Default b18a1 in 91 hatch dpfi to mpfi ISSUES omg
alright guyz hows it going im new here... but anyways lets get down to it... i just put a b18a1 swap in my 91 dx..
wiseco 9.8:1 comp pistons (forged)
eagle h beam rods (Forged)
king bearing set crank and rod
4-1 header
full exhaust in the mail
xs power intake manifold
and blah blah blah
anyway i had to do the dpfi to mpfi and thats whats giving me the hassle right now
the car ran fine before i swapped it... no issues at ALL!
may i mind you this is a 0bd0 set up
the fuel pump aint kicking on
but im getting spark
each injector when the car is on the "on posistion" gets no volts to it but when i try starting it, it jumps up to like 8.5 to 9volts (yes i have a resister box wired in)
yes i have all my grounds, the thermo stat one, the valve cover, the battery and chassis to tranny grounds they are all good...
i dont know what i coulda did wrong on my dpfi to mpfi swap
i took pins a1 a3 a5 and a7 snipped them and wired them to each corrosponding injector (had them marked and they are correct lol) i took the yellow/ black wire from the old injectors off the dx harness and wired that up to the resister box i swapped the c1 c2 with the b10 and b12 or what ever the crap that was, all i know that is not the issue
why isnt my pump kicking, why isnt anything working lol, the ecu (pr4) led light is off but when i tried pluggin up the pm6 i have from a zc the led was on
before you say hey there is a thing called goooooogle, well guess what i used it about a million times tryin to figure this **** out, all the people with the same problem solved them and never said what they did to fix it...
Old Feb 21, 2009 | 02:42 AM
Clipsed's Avatar
Default Re: b18a1 in 91 hatch dpfi to mpfi ISSUES omg
try swapping your fuel relay for a known good one, without being there to diagnose this problem would be interesting, because this is more a get down and dirty diagnosing situation.
I think the biggest problem of why it won't start though, is because your exhaust is in the mail!
Old Feb 21, 2009 | 10:07 AM
h224thgensedan's Avatar
Did you take the wire out of the driverside shocktower for the resistor box. Are you sure that your injectors are obd0 injectors.
Old Feb 21, 2009 | 10:37 AM
ef_b18a1's Avatar
yea they should be obd0 injecters due to the fact i bought the whole motor n tranny from a 91 integra... the integra was a running car...
what wire are you talkin about from the drivers side shock tower?
Old Feb 21, 2009 | 10:38 AM
ef_b18a1's Avatar
where is the fuel relay, theres like 30 relays under by the fuse box, i cant tell which one is which
Old Feb 21, 2009 | 03:24 PM
what wire do you have going to the yellow/black wire on the resistor box
Old Feb 21, 2009 | 07:12 PM
ef_b18a1's Avatar
the 2 yellow/black ones from the actuall harness itself... i had them ran from the ecu but proved to be more of a problem
btw im not gettin spark no more either..
Old Feb 21, 2009 | 07:51 PM
Are you gettin any cel also do you have any blown fuses
wleach11
Oct 7, 2004 05:44 PM
Civichatch27
May 23, 2004 04:15 PM
thaimonkee
12
Apr 20, 2003 09:53 PM
