Tial wastegate spring
You'll need to compare the spring chart with the spring you have. It will require opening the wastegate. Remember, the spring can take up to 2.5 times the pressure rate of the spring used. Example. if you have a 10lb spring, X 2.5 = 25psi...
accordfreak
Sep 10, 2003 04:37 PM
