How to remove rear hatch?
Old Aug 9, 2002 | 11:00 PM
MintyDip's Avatar
Default How to remove rear hatch?
How do i take off the whole hatch......yah the whole trink....????
Old Aug 10, 2002 | 08:23 AM
Mr.Rab's Avatar
Default Re: How to remove rear hatch? (MintyDip)
Is this a way to reduce your weight?
Old Aug 10, 2002 | 08:58 AM
MintyDip's Avatar
Default Re: How to remove rear hatch? (Dr. RAB01GSR)
hehehe no
trying to find a integra at a junk yard with rear hatch and no spoiler
figure just swap the hatches so i can still have that 3rd brake light.
Old Aug 10, 2002 | 11:47 AM
redGSRguy's Avatar
Let me know if you find any wingless milano red hatches.
Old Aug 11, 2002 | 11:48 AM
Jsracingintegra
Guest
Posts: n/a
Default Re: How to remove rear hatch? (redGSRguy)
There are bolts top of the hatch. Unbolt them and there you go! There also might be some wiring you need to unplug from the third brake light.
Old Aug 11, 2002 | 12:31 PM
MintyDip's Avatar
Default Re: How to remove rear hatch? (Jsracingintegra)
how do i get access to the tree bolts?
what about the gas shocks that push the hatch up? how do these remove?
Old Aug 11, 2002 | 03:10 PM
98AcuraGS's Avatar
You get a wrench and unscrew them from the hatch itself. Very easy i have done it before
Old Aug 11, 2002 | 03:15 PM
Quik Chris's Avatar
Default Re: How to remove rear hatch? (98AcuraGS)
You have to take the headliner out first, which requires you to take out the rear-view, the visors, and both lights, then there's the big plastic screw in the center-back area, turn in it 90°, and pull it out.
After that, there's 4 12mm bolts, 2 on each hinge. Then you might have to pound it a bit from the bottom, there's this wierd glue **** that they use. The wire harness is a bit of a bitch too, but work with it and you'll get it out. It's for the rear brake light, the wiper, and the defroster.
Lithel
Apr 7, 2009 08:48 AM
PhantomX
May 2, 2007 10:00 PM
Drian
Feb 23, 2005 06:01 PM
Understeer
Apr 27, 2004 10:31 AM
PSU
Jun 4, 2003 12:25 PM
