where is the sunroof draintube?!
so my sunroof has been leaking. i've ducktaped it shut and its hideous. lol. i was thinking maybe the draintube is clogged or leaking or something? can someone tell me where the drain tube starts and ends and all that? thanks a lot
i dont belive so.. just take the o **** handles off and the trim that meets the edge of the door .
But before you do that i would take your trunk interior side pieces off and check the tubes their because on my Da they were disconected and it leaked into my trunk bad.
even back seat and carpet suffered.
so basically the tubes run from the sunroof, to the sides of the car towards the trunk, and dumps out at the bottom of the car? or something like that?
ill check the trunk tubes tomorow. thanks
Good luck. and headliners arent that bad. just make sure you have all the screws out and the side pannels off then it will come down.
tubes run from the sunroof down each c pillar down the quarter pannel witch is where the connections are. then dump out inside the rear bumper on each side.
ep3og
11
Nov 29, 2012 05:47 PM
crappyshifting
Mar 7, 2012 05:24 PM
Noob Saibot
May 18, 2011 04:32 PM
pinoyboy204
Oct 14, 2003 09:04 AM
