obd0 to obd1
Old Feb 20, 2009 | 08:53 PM
lloydadvance's Avatar
Post obd0 to obd1
man i got something to ask....i have a mpfi ef4dr. obd0...i just recieved my chipped p06 ecu an obd1 conv . harness and i have a obd1 distrib. how and where do i wire the distrib.??? do i wire it off my already used distrib. wires??? and do i have to have a 4 wire o2 ??? or will my original o2 work??? SOMEONE PLEASE HELPPPPP.....
Old Feb 20, 2009 | 08:56 PM
D16SiHatch's Avatar
Default Re: obd0 to obd1
if you didn't get one with the ecu jumper you will need a 0 to 1 dizzy adapter so that you can plug your obd1 diz into the stock harness. and yes if you are utilizing an obd1 ecu you will need a 4-wire o2.
Old Feb 20, 2009 | 10:01 PM
Post Re: obd0 to obd1
my conv . harness has a sub harness with a 8 wire plug(FEMALE) an it has a male piece with 8 wires where does these wires plug up to???
Old Feb 20, 2009 | 10:45 PM
D16SiHatch's Avatar
there should be instructions that came with the jumper to tell you where they go. if not you'll have to trace the wires back to the jumper and figure out which ecu pin they go to. then look at an ecu pinout to figure out where they are supposed to go.
zapzach
19
Feb 24, 2012 10:35 AM
2_Envy
Mar 20, 2010 04:46 PM
ef dino
18
Oct 4, 2008 09:03 AM
hatch96y7
Jun 19, 2007 03:26 PM
wickedEFguy
Feb 11, 2003 03:01 PM
