difference between 02-04 vs 05-06 rsx
Im in the process of purchasing a k20z1 for my ek. i been doing some research but cant seem to find the answer. well the question is there a difference between the engine harnesses,and ECU
The ECU's are different for sure!
Wiring harness will be close... the VSS is different for the two gens and not sure if the plugs are different. So I'm not sure about the harness I would assume they are close but different.... but don't quote me
lots of stuff.....speed sensor in the trans is different,coil springs are wound in the opposite direction, lower ball joint is the same size as the type-r on the 05-06, the sways are different sizes, ft lca are different.
RC211V
17
Feb 17, 2005 09:32 PM
