quick question guys..obd0 to obd1
Old Feb 20, 2009 | 05:37 PM
bayron's Avatar
Default quick question guys..obd0 to obd1
hey guys i have 90 hatch b16a2... but its obd0 and i wanna put it obd1.. i have a p30 already but i know that i need jumpers,, but wuts else do i need 2 change in???? thanks
Old Feb 20, 2009 | 05:57 PM
EFRue57's Avatar
Default Re: quick question guys..obd0 to obd1
obd1 distributor, 4 wire o2 sensor, obd1 injector clips and injectors.
Old Feb 20, 2009 | 08:34 PM
lloydadvance's Avatar
hello i have a mpfi ef4dr. im conv. to obd 1 4rm obd0 i have a chipped p06 an conv. harness to obd1 do i still need 4 wire o2? i got obd1 distrib. do i wire this to my car harness that originaly plugs to distrib.? or 2 the 8WIRE sub harness on my obd1 conv . harness ?????
Old Feb 21, 2009 | 12:37 PM
Crx Jimmy's Avatar
get the ecu jumper harness, the obd1 distributor and distributor jumper harness, and 4 wire o2. you dont need to swap injectors or clips or remove the injector box if you already have them just use the obd0 injectors and keep the injector box.
Old Feb 21, 2009 | 05:00 PM
brixcivic's Avatar
exactly what he said..... to the V in vtec lol....
Old Feb 22, 2009 | 06:58 PM
Mr. Teal's Avatar
This guy is right
I have an obd0 EF and to get up to obd1 I got a new dizzy, ecu with all proper conversion harness' but I had an 02 Override chip so I had no issues with the 02 Sensor
It's always good to upgrade injectors but not manditory
Old Feb 22, 2009 | 09:25 PM
lunalink's Avatar
i have a question, lol... I have an 88 CRX DX auto.. i baught a DOHC ZC motor.. o.k heres the thing, this is my first complete swap it has a hydro trans i believe came off a '92-95 civic..i know i need a new harness and computer..so what do i need?
which computer, harness, what do i need to do to the firewall to make things work.
and im using the pedals and hydro converter from dc2 integra..need help BIG TIME!
Old Feb 23, 2009 | 03:13 PM
Mr. Teal's Avatar
lol damn man where do i start
well you need the cable to hydro conversion assembly first off
the auto to manual i'm sure you can search and find that info easily
that is a lot to type lol
and to be perfectly honest i read about those zc motors and they are pretty complicated and i keep reading about issues with them but rarely find and useful info
i know this isn't very helpful but do some more research and i'm sure you will find what you need
good luck
Old Feb 23, 2009 | 08:52 PM
lunalink's Avatar
kool thanx for the heads up..well i have pretty much everything i need except the cable and the linkage..i have the pedals, master cylinder and the hydro converter..i just want to know about the harness and computer basically..
lunalink's Avatar
if anybody can help it would be really helpful...thanx!
Old Feb 24, 2009 | 02:02 PM
Mr. Teal's Avatar
not to be mean man but you not searching for yourself
i googled what ecu to use with a zc motor
and fourth link down i found a link that looks like all you need
http://www.zcspeed.com/faq.htm
Old Feb 24, 2009 | 07:22 PM
Ass$nyper's Avatar
Pirate General...YARRRR
There are a ton of write ups on how to convert to obd1 and to do so I back www.Boomslang.us for a harness
Old Feb 26, 2009 | 12:38 PM
lunalink's Avatar
thanx guys..its gonna come in so handy..imma post my build on it soon..
Old Feb 26, 2009 | 08:04 PM
Mr. Teal's Avatar
good luck
90civicstdgold
Jul 7, 2011 03:20 PM
dc5itracer
10
Mar 26, 2011 10:29 AM
Fezzie
Aug 31, 2006 05:40 AM
EVOCELICA
Jul 9, 2004 01:10 PM
7rrivera7
Nov 9, 2002 06:38 AM
