Installing A/C into a Crx that... didn't come with A/C...
Old Feb 20, 2009 | 04:03 PM
boarderfatty's Avatar
Default Installing A/C into a Crx that... didn't come with A/C...
So don't let the newb post count fool you, and trust me, I've searched...
Looking at buying a 1991 CRX SI/SE with B18C5 swap, but the no A/C thing kills it for me... so I remember when we did my friends H2B CRX we removed all his OEM A/C parts in the engine bay....
So I have access to everything on the engine bay side... the question is now, what would I need in regards to wiring if this is dealer installed A/C is there a jumper harness or is the body already equipped with the harness even if the car does not have A/C. Obviously it would not be hard to make a harness if all else fails and if someone has done this before or has a link to how this is done and could post it that would be great. Is there anything I would run into that i would not expect when installing A/C into a non A/C car? I figure I will need...
A/C Lines
A/C Climate controls (No A/C button on regular ones)
A/C Exchanger core under dash and housing
A/C Condenser/compressor
Del sol B-D series A/C bracket
There is also aftermarket kits available.. anybody ever install one or have any info on something like this?
http://www.ackits.com/merchant.mvc?S...MA16765-003870
I was rushed writing this and have to cut this post short as I'm at work and keep getting harrassed!!
Thanks HT
Old Feb 20, 2009 | 04:18 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Installing A/C into a Crx that... didn't come with A/C...
Just adding to your list -
Condenser fan
NEW filter/dryer
New O-rings (get them.. don't cheap out)
A/C relay stuff that goes behind driver side headlight
Firewall grommet
There is a harness just for A/C that runs from the compressor and fan, to the relays, and off to the ECU and dash controls.
Harness is the thing covering the bottom left of this diagram
Old Feb 20, 2009 | 04:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://crxresource.org/modules.php?n...article&sid=11
Old Feb 20, 2009 | 07:42 PM
Thanks for the diagrams, I didn't even think about them!
Real world experience dealing with this issue has to fairly common!!! Dont let me down HT!!! I've been living in the shadows for sooo long lol.
freddy chavez
Dec 25, 2012 12:28 PM
sired
Jan 21, 2012 04:58 PM
hondaman177
Jan 23, 2008 02:02 PM
eric.
Jul 29, 2002 05:02 PM
