FS: 06-07 non SI civic parts
Not sure if FS posts are allowed in here, but since these parts that i have are very specific to the 06-07 civic (non SI) I figured I'd give it a shot. If it is not allowed to be posted in here, i apologize and a mod can do with it as he sees fit.
In 2006 ran an 06 Honda civic EX in the 25 hours of thunderhill and won our class, the next year we switched the car to an 06 Honda Civic SI and placed second in class.
We bought A LOT of spare parts for the civic EX, and most were not used. So now i am trying to get rid of all the parts that are just taking up space. All parts are BRAND NEW from Honda unless otherwise noted, some are used (coilplugs, and gauges). Here is a list of all of the honda part numbers and the description honda gives for them.
If you are interested please contact me VIA EMAIL MY EMAIL IS jimmysc13 "at" gmail 'dot' com
Prices will be heavily discounted, much cheaper then majistic honda or other sites.
I also have 1 complete (subframe included) r18 motor swap, it has around 35 hours of time on it, ran great and reliable for all of its life. I THINK this swap includes a KAAZ diff, but i will have to check some notes to be 100% sure.
I have another r18 motor (complete swap just no subframe) that has less then 1 hour on it, pretty much a brand new motor (new EVERYTHING from honda) that was broken in on the dyno.
44300-sna-951 06-07 non SI front wheel Bearing
9807b-561cw 06-07 non SI spark plugs
15100-rna-a02 06-07 non SI Oil Pump Assembly
06110-rnb-00 06-07 non SI Cylinder head gasket kit
54310-sna-a04 06-07 non SI wire change (shifter cables)
11200-RNA-A00 06-07 non SI oil pan assembly
37820-RNA-A09 06 non SI control module, engine
44305-SNE-A21 06-07 non SI driveshaft assembly RIGHT
170454-SNA-A30 06 non SI fuel pump module
54100-SNA-A02 06-07 non SI lever sub assembly
53601-SNA-A02 06 non SI power steering rack
19050-RNB-A02 06-07 non SI water filler assembly
19200-RNA-A01 06-07 non SI water pump
45019-SNE-A10 06-07 non si caliper sub assembly
44306-SNE-A21 06-07 non SI driveshaft assembly LEFT
19015-RNA-A02 06-07 non SI SHROUD radiator
53601-SNA-A02 06 non SI Power steering rack
36531-RNA-A01 06 non SI sensor (converter) o2 sensor
53540-SNE-A01 06-07 all models tie rod end RIGHT
32107-sva-a20(or a30) wire harness floor (used)
30520-rna-a01 06-07 non SI coil plugs (used)
other parts
06 civic EX gauge cluster with 4,869 miles (used)
06 civic EX speed display
again prices, pictures and shipping can be discuessed in email, with people who are serious.
other parts
07, 11200rnaa02, 2002, 30520rnaa01, 36531rnaa01, 37820rnaa09, 44300sna951, 44305snea01, 561cw, assy, civic, free, fuel, honda, module, part, plug, pump, si, spark
