DOHC ZC Help...Engine Bogs When I press On The Throttle
I did a search here on ht and didn't find anything on the subject.
we just installed a fresh dohc zc(obd1 rewired to obd0) and so far everything is fine except for the bogging.
when we press the throttle(wot)the car will bog down and hesitate but then rev fine.
We are running a pm6(crx si)ecu for now....it was the ecu i was running on my old zc(obd0) before i bought this new one.
we checked the timing marks on the cams and the oil pump and it all lines up fine.
if anyone has any ideas or insight i'd appreciate it very much.
thanks!
ps. we did a compression test and all cylinders held between 185-195 psi. so everything looks ok there. And no CEL's
thanks!
I got a 92 accord ex it's bogging on me I Replaced cap,wires,plugs,fuel filter and it's still doing it I removed the cat still nothing.Ran fuel pressure test it came back good so I'm pretty much stuck.....please any help?
Check out www.thezcr.com for Dohc ZC specific information
Ha Ha This is ridiculous It didn't Bog while they had it at the shop.....Unbelievable Man Really.... But of Course I get half way down the street and it did it................
ghettoda9
16
Apr 14, 2013 05:28 PM
