Fuel pump not getting power
on my 95 del sol it wont start still, the fuel pump is not getting power but i took it out and it works, i think its the wiring to the fuel pump because i have also replaced the main relay 3 times. help
what wiring harness are you running i had this same problem but i used a different harness then the original i used obd2a and the car was wired for obd2b that may be your issue if not disregard this comment...
