Few problems with the r
I just got an 99 jdm itr half clip from japan Motor trans ecu sup. Are in. They went in a 96 ls. Now my problems are the abs light is on, will that stop when I put the itr axles and brakes on? And my c.e. Light is on I have the test pipe with the o2 senor port and it's still on I tried to pull up codes and nothing comes up. And it only comes on when the car is warm and my vtec doesn't work till the lights on. Please help I searched trying to fix the problem myself And can't figure it out.
the 96 jdm itr did not have abs if i remember right. i actually have no idea if our ecus control abs. normally cars have stand alone abs modules. if you left your LS abs and everything intact nothing should have been effected unless it is the JDM ecu that does not have the abs feature. i wonder if a US p73 ecu would cure your problem? find out if the ecu and abs are in any way connected.
