sway bar problem need help!!!!!1
i have a skunk2 rear sway bar and a 99 gsr. i was wondering what i can do to reinforce the subframe so it wouldnt tear out when i put my car through hell. DOES ANYONE HAVE A SOLUTION!!!!!!! THANKS!
Maybe something like the beaks or BSQ kit would work with the skunk2 bar? They're designed for the ITR bar, but the diameter is the same so I think it should work.
hmm.. i was thinking about it and i think there might be a problem... there is 2 nuts welded to the chassis in the back of the subframe. how am i supposed to install the back plating (beaks mounting kit) if these 2 nuts are in the way? am i supposed to knock them off to get a clean flat surface? btw, how much would a typeR rubber bushing and Dbracket cost me at the dealers?
Not sure, on either question. I believe people cut/knock off that nut.
Check http://www.acuraautomotiveparts.net for prices.
just woundering, is it that easy to tear your subframe? i have rear sway bar for 2 years. i daily drive my car and go to tracnk event almost once a month. i didnt see any problem of my subframe.
YUP...remove the lower control arms, and get a chisel and hammer. Knock off both the nuts, flatten out the torn subframe sheet metal and the BEAKS kit, backs it up nicely. And will prevent future failures..
Tore both sides out of my Del sol, and the Beaks kit never failed...
Jeff
Jeff
where can i find such a kit? do u have a pic of it?
Here is a picture of the mounting kit.
[Modified by BSQ, 12:05 PM 8/12/2002]
1.) Go to http://www.acuraautomotiveparts.net/...searchpart.jsp and enter the following part numbers to check prices:
52315-ST7-Z01 swaybar bushing (2 needed)
52308-SS0-000 bushing bracket (2 needed)
blackstar
Oct 25, 2004 09:26 AM
ichibano
11
Feb 14, 2003 02:56 PM
