y8 manifold swap on my y7, now idle surge
Old Feb 20, 2009 | 06:19 AM
triple5soul4165's Avatar
Default y8 manifold swap on my y7, now idle surge
long story short i finished my y8 manifold swap yesterday and have had some issues
im using my y7 tb with a y8 rotor, and a y8 5 spd manifold with the IACV holes plugged
my map and tps arent mixed up, i have the proper coolant line going to the iacv, my vacuum lines are in the correct position
my idle is pulsing between 1000-2000 rpms rising then dropping then rising ect
also i think there is air in the coolant system, ive tried draining and refilling but the large lower hose doesnt seem to get hot like the others and feels empty
any help would be great, i already missed school to stay home and try and get this solved
thanks in advance
Old Feb 20, 2009 | 06:22 AM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: y8 manifold swap on my y7, now idle surge
did you convert from 3 wire iac to 2 wire?
Old Feb 20, 2009 | 06:27 AM
im using my 3 wire iacv from my y7 throttle body and using my y7 ecu
Old Feb 20, 2009 | 06:30 AM
http://www.youtube.com/watch?v=PgWJ9XRh5g4
idle is exactly like that
Old Feb 20, 2009 | 01:43 PM
-=Zeqs=-'s Avatar
Did you try switching your plugs for the MAP and TPS sensors on the throttle body? They both look identical to someone that wires everything up quickly. Hell, it gets me just about everytime.
Old Feb 20, 2009 | 03:20 PM
toyotatech1013's Avatar
what yeah y8 mani did u get if u got 98 -00 they have 5 extra vacum ports on flange that bolts to motor you have to block them off
TurboGoKart
Sep 30, 2009 02:53 PM
thedanny88
Dec 9, 2008 12:53 PM
combz
Jul 15, 2007 02:59 PM
max23
Oct 18, 2005 06:14 AM
