Car Wont Start After I Pulled Spark Wire!
Old Feb 19, 2009 | 10:14 PM
Cameron60's Avatar
Icon6 Car Wont Start After I Pulled Spark Wire!
I was working on my friends car when i pulled his Spark Wire to see if one of his cylinders was dead. I went down the line of pulling and placing the wire back.. all of a sudden it died after i got to the last cylinder (#4). Then his car wouldn't start back up! What should I do? Its getting fuel, air, compression, just no spark(i checked doing the spark plug 2 a ground test..no arc)!!! Has Anyone ever had this problem? What should I check? Thanks!
Old Feb 19, 2009 | 11:23 PM
dude_123's Avatar
Default Re: Car Wont Start After I Pulled Spark Wire!
High possible chance the secondary coils arched internally and caused a short. Try another coil. Also check timing to see if it jumped.
Old Feb 20, 2009 | 06:14 AM
fcm's Avatar
fcm
Old Fart
First thing I would do is make sure the distributor assembly is getting 12V+, should be black/yellow lead, if there is 12V+ at the black/yellow then check the coil and ICM, [ignition. control module] 94
Old Feb 20, 2009 | 03:44 PM
Bailhatch's Avatar
I think that can kill the coil...
Old Feb 20, 2009 | 07:31 PM
dtapia's Avatar
i have not seen that damage a coil but hey anything is possible.
i would check the icm. their is a test to check both the coil and icm in 1 shot.
Old Feb 20, 2009 | 07:42 PM
dtapia's Avatar
cody1234
Nov 30, 2012 05:34 AM
dakotagurule
Jan 31, 2012 06:05 AM
Cameron60
Feb 19, 2009 10:22 PM
Coolcat55
10
May 18, 2007 07:36 PM
wanttorace
Sep 23, 2003 12:01 PM
