Fuel Pump, should I upgrade for my setup
Old Feb 19, 2009 | 09:44 PM
EGgoJDM's Avatar
Icon2 Fuel Pump, should I upgrade for my setup
What up peps... I have a 93 civic cx eg hatch. I swapped in a 98 spec jdm b18c itr engine that I build with skunk2 pro2 cams, skunk2 pro valve train( flat face valves, springs and ti retainers), skunk2 pro IM, BBK 70mm TB, benen fuel rail, precision 310cc fuel injectors, password whale dick, head ported and valve job. I want to know if the stock fuel pump and fuel filter will keep up with my engine setup? and What are the Lph of a 93 civic cx stock fuel pump? thanks
Old Feb 22, 2009 | 08:11 AM
sander's Avatar
2.7(p/t)
Default Re: Fuel Pump, should I upgrade for my setup
Your stock fuel pump will be fine. Not sure on the LPH measurement although, It will be fine from ones that I have done in the past similar to that.
Old Feb 22, 2009 | 11:43 AM
Ls_dx's Avatar
Yep stock pump should be fine as long as its in good working shape.
rth_1984
Aug 3, 2011 05:04 AM
EGgoJDM
Feb 16, 2009 07:22 PM
Hybrid Invasion
Oct 2, 2003 05:10 PM
