noobi build questions?
Old Feb 19, 2009 | 05:18 PM
cheapshot's Avatar
Default noobi build questions?
ok, sorry if you have heard these questions before, I want to get a motor built, I have a ls with 150,000.
I don't know what a built motor really is? are all parts new, except block?
what is the process from block, pistons, rods, head, cams, valve springs, intake manifold etc.
also i am looking for a 210whp give or take all motor, for everyday to work, reliable fun driving.
I am confused on compression, and don't know much about motors. should i use aftermarket pistons? manifold? cams? are they more durable and relieable?
should i go,
1. gsr-ctr pistons?
2. gsr-typr r pistons?
3. gsr-stock pistons?
should i go,
1. stock gsr head?
2. gsr head typr r internals?
3. gsr head with aftermarket valve springs cams?
I want relieable fun.
thanks in advance for your help
Old Feb 19, 2009 | 05:48 PM
95civhb's Avatar
Default Re: noobi build questions?
start reading...
search when you have specific questions... and then, and only then, if you can't find the answer, post and ask...
start reading threads.. that's the best way to learn...
stratedrm
May 17, 2009 07:09 PM
LOMPSEG
Apr 3, 2009 05:48 PM
cheapshot
22
Feb 23, 2009 02:14 PM
blwn95civic
Oct 12, 2006 01:39 AM
