B18C1 GSR Help. [Doesn't Start]
Old Feb 19, 2009 | 02:22 PM
atmospheric SOUL's Avatar
Default B18C1 GSR Help. [Doesn't Start]
I`m a little new with Engine work and all that. A Couple Months ago, I Seafoamed my car because a friend of mine told me it was good for my engine and it would clean out all the carbon build up [160xxx Miles]
I put the Vacuum Hose connecting from the Intake Manifold > Firewall [Disconnecting from the Firewall] into the bottle. Literally not even 1/4 of the bottle went in. Bottle still looks Full. I Forgot to Throttle the engine and my car bogged and stalled. He said that was normal and just wait for about 30 minutes. 2 Hours later my Car still doesn`t start up. I replaced my sparkplugs and everything and still no good. The Car still Cranks and everything works fine, it just won`t Start.
My Friend told me it was a Chip in my Distributor so i`ll replace it anyways.
I Have 2 Questions; if you guys could kindly help me out please.
1. How do i take off the Silver Rotor in my Distributor Cap ? It's Stuck on there pretty good and i don`t see another screw holding it in place.
2. Are there any other Solutions i should consider that would be wrong with my car ? [ignition Coil, Anything inside my engine, etc.]
Thanks in advance. I Really want me car to get running.
Old Feb 19, 2009 | 03:02 PM
omgwtfbbq's Avatar
Default Re: B18C1 GSR Help. [Doesn't Start]
Take your dizzy off, and turn the rotor slowly, you'll see a phillips head screw on the side...thats holding it on.
Old Feb 19, 2009 | 03:16 PM
I Can`t turn the rotor at all. It just wiggles left and right a little.
Old Feb 19, 2009 | 03:19 PM
omgwtfbbq's Avatar
you have to take it off, cuz the cam is restricting it from turning. You could avoid taking it off by turning your whole motor at the crank....or just take off the 3 bolts holding it on.
Old Feb 19, 2009 | 04:04 PM
I Just want to take off the rotor to see the chip inside.
I Was reading through Team Integra and some guy 3 Years ago had the same problem as me, putting it in the same place and it won`t start. He said his Ignition Coil shorted out and after he replaced it, it ran. So i`m going to replace it and see what`s up.
Old Feb 19, 2009 | 04:13 PM
delbert's Avatar
dude you have to take off your distributor. to be able to spin it and you'll the screw holding the rotor in and unscrew that out. and there you go. i think your friend ****ed up your motor lol just saying. your rotor still looks like it looks good though. but theirs that wierd curve in the middle of the rotor though..if your car won't start it usually be most like spark or fuel. test ur spark first. stick a phillips in the spark plug hole and see if it sparks or if you hear it spark.
Old Feb 19, 2009 | 04:15 PM
omgwtfbbq's Avatar
I understand you want to just take the rotor off, but to access the screw holding it on, you need to spin the rotor. The rotor will not spin while the dizzy is still attached to the cam....unless you turn the crank. Three bolts, the dizzy comes off, you can turn it a little and see the screw. Simple...can't take more than 15 minutes to do.
Old Feb 21, 2009 | 10:57 PM
99lsvtecintegra's Avatar
New User
Just leave the distributor cap off like the picture show, then disconnect the two connectors at distributor, after that crank the engine like (click click) until u can see the bolt of the rotor, don't need to take the distributor out.
Old Mar 17, 2009 | 12:16 AM
Fixed The Problem ! The Seafoam Problem was my Ignition Coil. $75 to Replace it, but it was oh so worth it. Thanks for the help everyone.
danielsan95
60
Jul 22, 2017 08:11 AM
4drint3gr4
29
Apr 9, 2010 12:21 PM
luisda4th
Feb 23, 2008 02:31 PM
az90civic
Sep 1, 2007 05:51 PM
hondaitegra
Jun 30, 2003 09:34 AM
