from 2000 Acura TL HID kit --> Integra
Old Aug 9, 2002 | 07:29 PM
TurbothisLS's Avatar
Default from 2000 Acura TL HID kit --> Integra
I picked up a HID kit from a wrecked TL. It includes the ballast, igniter, and bulb. I dunno how the heck I'm going to make this work, but just wondering if someone has done this before. The bulb won't fit in my headlights, I have no idea where to mount the ballast and igniter. ANYONE know about this please help!
Old Aug 9, 2002 | 07:30 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: from 2000 Acura TL HID kit --> Integra (TurbothisLS)
someone has so try a search
Old Aug 9, 2002 | 07:31 PM
uNF$@#!'s Avatar
Default Re: from 2000 Acura TL HID kit --> Integra (dLo GSR)
splice into connector, tap it into the ignitor or the ballast , and off you go.
Old Aug 9, 2002 | 07:43 PM
Default Re: from 2000 Acura TL HID kit --> Integra (Soup ****)
what about the bulb?
The bulb won't fit in the headlight.
should i modify the headlight to accept the bulb???????
what should i use to seal it off
Old Aug 9, 2002 | 08:47 PM
tekstyle's Avatar
hey, i have a pair of 9005/9006 HID bulbs that might work with ur ballast. these bulbs will fit right into ur headlight housing socket. i have a gsr so i know. i'll sell them to u for $80 bucks +plus $10 shipping if u want it. i am selling them cuz they looked like s2000 or mercedes' HID and i was aiming for the lexus look.
Old Aug 9, 2002 | 08:55 PM
Jesse H's Avatar
Default Re: from 2000 Acura TL HID kit --> Integra (tekstyle)
people get HID's for look and not performance? What's this world coming to? Ahhhh!
Old Aug 9, 2002 | 10:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Those HID capsules are D2R, for reflector housings... the beam pattern will be totally wrong if you use them in a projector housing, you need D2S capsules made for projectors.
Old Aug 10, 2002 | 06:55 AM
JeffNA's Avatar
If you want to use the TL bulb, you must remove the ring with the 3 screws in the housing. Place the bulb inside, use a little epoxy, and put the ring back. Modify the bulb not the housing. Its cheaper to replace a bulb than the housing.
But if you want a decent looking setup for half the price of a new HID Setup. Use the TL ballast and buy HID bulbs that fit perfect in your housing. Cause the TL bulb is short unless you modify the bulb deeper into the housing. I done this setup before on my Teg. I just ended up purchasing a new set of HID bulbs and used the existing TL ballast.
If anyone is interested I have a set of TL ballast (No bulbs) for $200 shipped
The HID setup is a direct splice and dice connection.
Old Aug 10, 2002 | 09:21 AM
Default Re: from 2000 Acura TL HID kit --> Integra (JeffNA)
so just remove the ring inside the headlight, put the bulb in and put the ring back + use epoxy? is this process reversible?
thanks
JOe
Old Aug 10, 2002 | 09:26 AM
and will the lights look right in my projector housing?
Old Aug 10, 2002 | 01:05 PM
jeffna where u at??
i need help! anyone
Old Aug 10, 2002 | 02:28 PM
ILOVEGIRLS's Avatar
u have IM.
Old Aug 11, 2002 | 07:18 AM
JeffNA's Avatar
I'm in NJ. Sorry TurbothisLS, The process is not reversible. Once you epoxy the bulbs you can't take them out unless you chisel them out. Not worth it. But HID bulbs last forever, I mean quite a while, they last longer than conventional bulbs. I did this setup and it good. You just have to position the bulbs straight.
Old Aug 12, 2002 | 10:43 AM
hey,
the bulbs went in straight, but the beam is on the ground. i can't get the beam to come up. is there a certain way to put the bulbs in? i.e. bar up or bar down??
i can't see jack, the light is on the ground and I've tried moving the headlight and adjusting the leveler.
help!
thanks
Old Aug 12, 2002 | 12:16 PM
need help!
Old Aug 12, 2002 | 12:50 PM
neo1z's Avatar
i would avoid ghetto rigging it and go the right way....use the ballasts...new bulbs.
-rob
Old Aug 12, 2002 | 05:16 PM
tekstyle's Avatar
bulbs for sale man.... just gimma a hollar!... at tapiocajai@hotmail.com
Old Aug 12, 2002 | 09:01 PM
JeffNA's Avatar
There is a certain way of putting the bulbs in but its trail and error. Just save your self some hassle and buy the bulbs.
Old Aug 25, 2002 | 09:06 PM
pkek's Avatar
Default Re: from 2000 Acura TL HID kit --> Integra (Jesse H)
EXACTLY jesse..
I'm buyign them because I feel i wont hit deer so often liek I did last year
Old Sep 3, 2002 | 01:38 AM
ILOVEGIRLS's Avatar
jeffna, can u get bulbs for a good price?
Old Sep 3, 2002 | 06:42 AM
JeffNA's Avatar
Default Re: from 2000 Acura TL HID kit --> Integra (ILOVEGIRLS)
I'll keep you posted. I'm waiting for get some prices.
lil kid
Honda Civic (2001 - 2005)
11
Aug 21, 2008 02:26 AM
sireg6
Lighting
Jun 23, 2008 06:30 PM
BKKloppenborg
May 13, 2008 05:36 AM
GSRACCORD
Jan 29, 2004 02:25 PM
Hella Clean
Jul 15, 2002 06:28 AM
