what is a "clock spring" ?
I'm guessing 'they' are referring to the electrical/mechanical connection between the steering wheel and the steering Column.
Pull the steering wheel and see what you can find...
its a spring in a time clock that helps it operate properly....
j/k its also known as a cable reel. when you take your steering wheel off you will notice a piece of plastic with a couple of wires and a conector sticking out of it. it rotates. any ways thats what your looking for. g/l
incognito21
Acura TL, RL & ZDX
Feb 23, 2005 09:20 AM
