where can i get a vtec pressure switch?
Old Feb 19, 2009 | 10:37 AM
billmongold's Avatar
Default where can i get a vtec pressure switch?
i need the 2 pin switch/sensor that goes in the threaded hole in the side of the vtec solenoid. i cant find one locally. any help is much appreciated. is that even what it's called?
Old Feb 19, 2009 | 10:41 AM
fatpride111's Avatar
Default Re: where can i get a vtec pressure switch?
dealership item. itl run you around 60 or so dollars.
Old Feb 19, 2009 | 11:04 AM
jade infamous ek9's Avatar
pretty much any pressure switch will work so if you can find a junked motor with a solenoid you could use that pressure switch. but if still no luck then to the dealership you go. good luck
Old Feb 19, 2009 | 09:03 PM
found one on fleabay for 30. thanks guys
Old Feb 20, 2009 | 12:25 AM
trustdestruction's Avatar
more expensive, but brand new.
for future reference for searchers (not that anyone uses the search )
http://inlinefour.com/oembvtoilprs.html
monkeymk2
Feb 26, 2019 10:49 PM
pkolaboy
May 28, 2008 05:43 AM
GSR_hatch936
May 17, 2008 11:39 AM
projecthonda
Feb 27, 2007 09:15 PM
