96-98 Civic TSX H.I.D. retrofit for sale!!!
SOLD!!!!!!!!!!!
This is not a P-N-P hid kit! These are retrofitted into OEM 96-98 civic housings! Not aftermarket projector housings! Headlights don't leak! I did these myself 6 months ago with no problems what so ever. TSX clear lense single low beam xenon projectors (no high beams) with Phillips 85122+ bulbs with around 75 hours and oem BMW ballast. I am also including the full h.i.d. H4 wiring harness that you need to keep your stock headlight wiring harness from burning up. I also painted the cutoff shield flat black (thanks to hidplanet) to prevent excess glare to make the cutoff sharper. The stock headlight adjustments work like they are supposed to so the in/out/up/down work! The width of the beam is set. All you'd have to do is adjust the height accordingly since your car may be lower/higher than mine. I can take additional pics if need be. Below I posted some pics I took of the retro when it was on the car, enjoy! Shipping charges will be added accordingly. If you are in Florida i'm will to drive an hour or so to meet up for a sale. I'm located in the Tampa area. PM me if interested!
Inside view:
About 25ft from an off white garage door:
Wiring harness/ballast:
Inside view:
