H22 swap into 4 DR!!!!
Old Feb 19, 2009 | 09:10 AM
benawhati's Avatar
Default H22 swap into 4 DR!!!!
As the title says i am swapping a H22 into a 94 dx 4dr!! Anyway, i just need some opinions... Is it easier to mount the shifter box and run the cables in before or after the motor is in... also, what is the best vtec crossoer point and rev limit?
Old Feb 19, 2009 | 09:35 AM
Allurian's Avatar
Default Re: H22 swap into 4 DR!!!!
Easier to run cables after trans is in position so that you know cables are in correct position. But if I were you I would just source a bseries trans and h2b kit. It'll save you from having to cut a hole for the shifter box and the btrans are much better
Old Feb 19, 2009 | 09:48 AM
benawhati's Avatar
i thought about the h2b kit, but i am just going to hold off on that... Im not worried about the hole, it can always be welded shut again if needed
Snailor Built
Nov 19, 2014 06:10 AM
jbell
Dec 11, 2004 10:38 PM
jbell
Dec 6, 2004 07:36 PM
h22-cx-guy
Jun 30, 2004 11:40 PM
