axle swap question
An Eg hatch with a gsr swap will the axles fit my 89 crx with the swap??
Thanks...
Also Will i nieed a rear tranny bracket or can i use the one on the eg
Also will the shift linkage work or will i need one from hasport
Thanks...
hasport linkage
rear bracket if you are talking about the t bracket will work
axles might fit - depends on what model crx - in 4 days I would assume you would have tried by now
i can only answer the first and last one question,
1. as long as your crx is not a hf
2. not to sure on this one but the rear tranny bracket should be the stock one from the gsr. so in the end, you shouldn't have to do anything there
3. need a hasport or custom that shift linkage, cause it's to long for your crx.
I have an 89 Si.. Ok so the t bracket will fit.. kool Cuz hasport sells the bracket and thought it was a custom one..
Thanks guys
Thanks
streetsold6teeny8
Mar 25, 2009 07:41 PM
streetsold6teeny8
Feb 27, 2009 09:24 AM
