how high are you revving your H22
Old Feb 19, 2009 | 07:05 AM
H2BSTUPID's Avatar
Default how high are you revving your H22
Just wondering how much everyone is spinning their all motor engines??
and what kinds of mods are done!
Thanks
Old Feb 19, 2009 | 07:06 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: how high are you revving your H22
Check the dyno thread up top.
Old Feb 19, 2009 | 01:01 PM
h22ej8's Avatar
^ has a good point, but for what its worth i ran my 100% (internally) stock jdm h22 to 8200 for 3 years without issues.
Old Feb 20, 2009 | 05:32 PM
mHeant2B's Avatar
h2b 8300 no problems
Old Feb 20, 2009 | 05:46 PM
h224thgensedan's Avatar
Spun my h2b to 8100 with no issues but i also didnt beat on it a bunch
Old Feb 20, 2009 | 06:18 PM
NABeastRR's Avatar
8200 rev limiter h2b
Old Feb 20, 2009 | 06:30 PM
Pinho's Avatar
always 8700....hit 9500(built motor) on the dyno a few times but it does not make the power i want up top
Old Feb 20, 2009 | 06:41 PM
98vtec's Avatar
moderator emeritus
~8300 in racing situations. I just took some measurements with a bore gauge to check for roundness and i just bought a couple micrometers so i can buy some new bearings but when i get some more info, i will post up about it. This certain block saw 8300 quite a few times and the wear patterns on the bearings sure dont show it taking any abuse.
Old Feb 21, 2009 | 05:02 AM
H2BSTUPID's Avatar
And for the h2b peeps, who are running a b16 tranny... on the strip are you guys comming out of 4th gear at the end??
i will have 23x8x13 slicks and i don't know if i'll be ok!! i really don't want to shove it in 5th gear at the track!!
Old Feb 21, 2009 | 10:00 AM
Im using a J1 trans. Check out mfactory's web site. They have gear calculators on there.
Old Feb 23, 2009 | 06:06 AM
ssaccord92's Avatar
does anyone have stage 2 cams or better and using stock valvetrain by any chance and if so how high much did u spend it.
Old Feb 23, 2009 | 06:12 AM
2fastGSR's Avatar
King of the One Liners
9700 . . . ..
Oh wait that was a mis shift . . . oops . .
8100 on a stock h22
9100 on a 90x102 build. . .
Although most H series builds I see dont make power much past 8500 anyways
Old Feb 23, 2009 | 06:13 AM
alterdcreations's Avatar
8500 rpms with the 95mm crank.
same with the new 97mm engine thats going in
racing shift points.
on a daily drive i dont rev past 8000.
Old Feb 23, 2009 | 07:27 AM
98vtec's Avatar
moderator emeritus
here are my main bore roundness measurements from the h22a
Main1
0/180* = -.0303"
45/225* = -.0287"
90/270* = -.0276
135/315* = .0291"
Main2
0/180 = -.0298"
45/225 = -.0292"
90/270 = -.0285"
135/315 = -.0294
Main3
0/180 = -.0300"
45/225 = .0291"
90/270 = -.0286"
135/315 = -.0298"
Main4
0/180 = -.0301"
45/225 = -.0291
90/270 = -.0286"
135/315 = -.0299"
Main5
0/180 = -.0300"
45/225 = -.0288"
90/270 = -.0281"
135/315 = -.0294"
I'll do the rod roundness when i get a chance. I bought a couple mics the other day and im waiting for them to come in so i can measure everything for bearings. Back-up blocks ftw
Old Feb 23, 2009 | 08:39 AM
ssaccord92's Avatar
what type of arp bolts are u guys using for the h22/f22 crank and rods. B/c i got some arp gsr rod bolts and they cam up short. I only had 4 threads for the lock nut.
Old Feb 23, 2009 | 10:22 PM
honda-will's Avatar
9000+ on my f20b i feel like it belongs in the h22 conversation.
Old Feb 23, 2009 | 11:06 PM
fatboy1185's Avatar
Big Cat
i take my f20b to 8500, type s cams, stock block.
Old Feb 23, 2009 | 11:16 PM
lexan2.2sedan's Avatar
Since 2003, (same stock jdm, shaved head, motor I have had in 3 street/strip cars) The limiter has been set @ 8175, I shift one nut hair before the soft limiter hits. But she only makes power til 7700 and some change.
This season I'll be testing out a few 8300 (with like a 8310 rev limit) shifts as I think I can get ~ .30 knocked off my 1/4 with a later shift.
Old Feb 24, 2009 | 07:44 AM
NAH2B's Avatar
stock internal h2b w/ b16 trans-8700rpm all day at the track, crossing traps in 4th around 8500rpm
Old Feb 24, 2009 | 08:45 AM
ssaccord92's Avatar
so no one is using upgraded rod bolts to spend these things
Old Feb 24, 2009 | 01:11 PM
NAH2B's Avatar
no you do not need to upgrade your rod bolts.
Old Feb 24, 2009 | 04:43 PM
kinday's Avatar
I'm doing 8500 rpm. No need for rod bolts like NAH2B said....I do believe that the H is stronger than we give it credit for.
Old Feb 25, 2009 | 04:27 AM
ssaccord92's Avatar
sorry should have said before i mean i'm talking about with f22 crank/rods u guys are still running f22 stock rod bolts and all turning 8000+ rpm.
Old Feb 25, 2009 | 04:52 AM
H2BSTUPID's Avatar
so your trapping 8500 on the strip in 4th?? is that with b16 tranny and 22x8x13 slicks?
Old Feb 25, 2009 | 05:18 AM
2fastGSR's Avatar
i was crossing the traps @ 8000 in 4th gear with a CTR trans w/ 4.7fd
