nrg quick release
what do you guys think of a nrg quick release on my 04 civic? DO yall have anykinds of problems or is it pretty clean? Can you post some pictures i would like to see what yall have thanks
I have NRG short hub and v2.0 quick release. With Personal Neo Grinta 330mm.
I like it, changes the feel of the whole car haha. The airbag light will stay on, but I found a way around that... sort of
older pic with the wheel on..
so whats the the difference in the version besides one being newer than the other? will u recommend the newer version. and is the shorter hub better as well? does anyone have a DIY so i can see how much work is requried thanks guys?
You need a hub regardless, bud. The quick release can't mount directly to the splines on the steering column. And without some sort of custom adapter plate, you won't be able to mount a steering wheel to a short hub. In essence, I'm saying that you need both the short hub and a quick release to mount the steering wheel properly.
chapagetti
May 29, 2009 10:29 AM
