need your advice: GSR swap PLEASE!
Old Aug 9, 2002 | 06:40 PM
NOSpeed97's Avatar
Default need your advice: GSR swap PLEASE!
someone is selling a 98 gsr swap with 71000 miles. this is in the bay area. how much should l pay for it? this is going into a 2000 hatch.
Old Aug 9, 2002 | 06:48 PM
Y2K Si FBP's Avatar
Default Re: need your advice: GSR swap PLEASE! (NOSpeed97)
full swap with no shipping involved?
if it's full...engine/trans/ecu/linkage/axles/harness etc...i'd prolly pay 2800-3200 tops...check the compression make sure it's a strong motor if possible
Old Aug 10, 2002 | 03:45 PM
00CIVICwB18C1's Avatar
if you're going to get the swap, go ahead and call mahdavi motorsports in georgia or king motorsports to get an ecu harness jumper so you can use the gsr ecu. mine from mahdavi cost i think 245 shipped. you won't be able to use the gsr's harness or even one from a 96-98 civic. i know, i tried. just be sure you tell them everything about the motor and car it's going into so you get the right harness. it might take a while to get to you. mine was on hold for backordered parts for like 2 months. but your stock ecu should power the motor for a while if that happens. i was runnin mine on a stock EX ecu for 4 months. But good luck with your swap if you get the motor.
BTW, i paid 2600 for motor, tranny, ecu, axles, shift linkage...even had power steering and a/c compressor.
[Modified by 00CIVICwB18C1, 5:46 PM 8/10/2002]
Runamok81
Honda Civic (2001 - 2005)
10
May 13, 2020 03:21 PM
kasperxtcy
Dec 23, 2007 04:42 PM
eghondafamily
Aug 11, 2006 11:28 AM
spunky424
Jul 23, 2006 07:18 PM
B18C1 '96 Coupe
Jan 1, 2003 05:13 PM
