f23 build N/A
im looking into building a N/A f23a1 outta my 98 cl and i was wondering .. if there was interchangable parts with the motor out of any other car to make it a Stroker for higher revs per min and give it Alot more tQif u guys have any lists of interchangeable parts what ever it is .. ie: pistons, rods, wrist pins, crank, heads valves ANYthing .. please post it up .. i wanna get started on this build ASAP and id really appreciate the help on getting the things togeather ..i will be posting pics of before and in progress and after.
-Thanx
-Thanx
well if you bore to 87mm i know h22 pistons will fit in the block...also k20 pistons will fit because the f23 and the k20 share floating wrist pins...u should check this out
https://honda-tech.com/forums/honda-prelude-4/new-frankenstein-engine-%3D-g23-f23-h23-write-up-long-56k-beware-1046336/
