FS:1999 GSR SWAP complete
Old Feb 18, 2009 | 08:19 PM
fmrprojects's Avatar
Default FS:1999 GSR SWAP complete
SOLD!!!!!!!!!!!!!!!!!!
Old Feb 18, 2009 | 09:19 PM
TeamRiskEG6's Avatar
Default Re: FS:1999 GSR SWAP complete
bump for a clean swap
Old Feb 18, 2009 | 09:25 PM
redGSRguy's Avatar
Is this the sick civic on mf10Ls? Goin K?
Old Feb 18, 2009 | 09:41 PM
nah going with different motor
Old Feb 18, 2009 | 09:54 PM
eklum's Avatar
clean engine bay
Old Feb 18, 2009 | 11:27 PM
xxintegracrxx's Avatar
Originally Posted by eklum
clean engine bay
x2, loving the wiretuck
Old Feb 19, 2009 | 12:28 AM
scubajosh's Avatar
x3
Old Feb 20, 2009 | 07:19 PM
Originally Posted by fmrprojects
i have a complete 1999 acura integra gsr swap for sale. comes with everything you will need to drop it into a 92-95 civic or 94-01 integra. this is a obd-2 motor but everything was converted to obd-1. it came out of my 1994 honda civic. motor is very clean . has 140k miles. i replaced the timing belt, water pump, alt belt, spark plugs, wires, cap+rotor, thermostat, pcv valve, and upper and lower radiator hose. also has brand new exedy stage 1 clutch with only 1500 miles. all new tune up parts has 1500 miles on them and all from acura. compression is 210 across and 6% leakage. very clean motor no problems at all. also has vin tag still intact on the block. comes with block, head, intake manifold with all sensors, fuel rail and injectors, throttle body, transmission, starter, axles, engine wiring harness, shift linkage, axles, and ecu. everything you will need to do a swap. asking $2200firm. call 408 687 8727 mike
eghatch9295
Jul 14, 2013 08:13 PM
Turbo02si
Jul 29, 2012 10:01 PM
Chizle707
Northern California (Sales)
Sep 2, 2008 10:18 PM
lsjon
Mid-Atlantic (Sales)
14
Mar 13, 2008 02:47 AM
nsxtasi
May 2, 2007 01:12 AM
