NEED HELP! B20/Vtec
Old Feb 18, 2009 | 08:15 PM
EG Coupe Frank's Avatar
Default NEED HELP! B20/Vtec
I cant figure out my compretion ratio,
81.4 mm stroke b17 gsr crank
86 mm bore CP 13:1 pistons
42.7 cc combustion chamber b16 head
7.7 cc piston dome displacement
151.562 mm eagle 5.967 rods
211.84 mm b20 deck height
0.029" oem thicknesss head gasket with a 86mm bore
any help?
I would like to be around 12:1 max.
Last edited by EG Coupe Frank; Feb 18, 2009 at 08:43 PM. Reason: Clearing up the muck.
Old Feb 18, 2009 | 08:26 PM
turbociv910's Avatar
Default Re: NEED HELP! B20/Vtec
b17 itr crank?
Old Feb 18, 2009 | 08:27 PM
yeppers
DC_Legacy's Avatar
How can you run an OEM HG with an 86mm bore?
Old Feb 18, 2009 | 08:29 PM
oem thickness i think i have to to keep the compresion down
Old Feb 18, 2009 | 08:31 PM
b17 itr crank?
what motor did that come out of????
DC_Legacy's Avatar
Ok, so are you saying the gasket bore is 86mm, but the thickness is .029"?
Old Feb 18, 2009 | 08:38 PM
yes thickness is 0.29", that is the thickness of a oem gasket correct me if im wrong.
Yes the b17 crank out of a gen 2 gsr integra.
DC_Legacy's Avatar
Also, are you using custom compression height pistons since your rods are 151.56mm?
Old Feb 18, 2009 | 08:40 PM
DC_Legacy's Avatar
Yes, thats the ~ compressed thickness but you havent confirmed the gasket bore diameter.
Ok, I see your edit now.
Old Feb 18, 2009 | 08:42 PM
gasket bore diameter would be the same as the bore 86mm.
Old Feb 18, 2009 | 08:48 PM
DC_Legacy's Avatar
Are the pistons custom made? Because your average aftermarket B-series piston (30mm comp height) will sit ~ 10.42-10.5mm above the deck with those rods & stroke.
Old Feb 18, 2009 | 08:56 PM
no, this is part of what im trying to figure out
stock stroke is 95mm half of which is max heigh from center line on the crank which is 42.5mm
stock rods are 141.7mm for a total of 184.2mm
81.4mm/2= 40.9mm+151.967mm=192.867mm
deck height is 211.84mm-192.867mm=18.973mm
im no pro but this is how i figured it
Old Feb 18, 2009 | 08:58 PM
the no was for these are not custom pistons.
Why did you call it a Type-R?
Those are two different crankshafts.
Old Feb 18, 2009 | 09:00 PM
Because Im a little slow
Old Feb 18, 2009 | 09:03 PM
DC_Legacy's Avatar
Your math is right.
Your rod is too long
81.4mm (stroke)/2 + 151.56mm (rod) + 30mm (avg B-series piston comp height) = 222.26mm
Old Feb 18, 2009 | 09:10 PM
So there will be enough room they will not hit the head? It will actually be 15.2mm below where the stock center line of the wrist pin would fall.
Old Feb 18, 2009 | 09:20 PM
DC_Legacy's Avatar
You stated the deckheight of your B20 is 211.84mm which seems right because I've measure my LS block before and it came out to damn near the same specs.
Im saying that your piston will be popping out the cylinder, and will very likely make contact with the head. I'd sell those and buy the proper size rod for that stroke (with that block), although there isnt much aftermarket support for that crank so if you want to use it you might have to have custom rods made.
You'd probably be better off just getting a B18 A/B crank with the appropriate rods, IMO.
Old Feb 18, 2009 | 09:30 PM
Im trying to keep it close to a 1.75 rod/stroke ratio.
The B18 and B20 have the same deck height I thought the B20 was higher?
My head is going to explode.
Old Feb 18, 2009 | 09:35 PM
DC_Legacy's Avatar
The B18A/B & B20B/Z Im 99.9% sure have the same deckheights + utilize an 89mm crank w/137mm rod
Old Feb 18, 2009 | 09:47 PM
Really? Wow if I would have know that it would have saved me a ton of time.
Old Feb 18, 2009 | 09:49 PM
I did the math again with a shorter eagle rod it will be a little taller longer than the stock setup
https://honda-tech.com/forums/showthread.php?t=2504346
Stock B20
95mm stroke
42.5mm from crank center line
+142.75mm rods
___________________________
185.25mm total height
-211.4mm deck height
-26.15mm from top of the deck
My setup
81.4mm stroke
40.9mm from crank center line
+148.895mm eagle rods
189.795mm total height
-21.605mm from top of the deck
Old Feb 18, 2009 | 09:51 PM
DC_Legacy's Avatar
The B20A & B21 block might have a higher deckheight, but I honest dont much about that block so I couldnt say for any certainty.
Old Feb 18, 2009 | 09:56 PM
DC_Legacy's Avatar
I did the math again it will be a little taller longer than the stock setup
Stock B20
95mm stroke
+142.75mm rods
My setup
81.4mm stroke
Right, but as you know you still have to account for the piston compression height.
