ABS Delete on 2001 ITR
Old Feb 18, 2009 | 05:03 PM
Boosted_01 R's Avatar
Default ABS Delete on 2001 ITR
Hey guys, found some info on removing ABS, and was wondering if you guys can clear some stuff up for me
Any other things I need to know or buy?
Which part #'s is for the the 98+ integra's
(1) 46310-ST7-A11 PIPE A, BRAKE
(1) 46320-ST7-A11 PIPE B, BRAKE
(1) 46321-ST7-A11 PIPE H, BRAKE
(1) 46360-ST7-A11 PIPE F, BRAKE
OR
46310-ST7-A00 PIPE A, BRAKE #6 - prop valve to pass brake
46320-ST7-A00 PIPE B, BRAKE #7 - prop to MC
46321-ST7-A00 PIPE H, BRAKE #8 - prop to MC
46360-SR3-A02 PIPE F, BRAKE #11 - prop to drivers brake
Also I know i need a 40/40 prop valve.
THANKS
The removal process has began
Old Feb 18, 2009 | 05:18 PM
YellowKahuna's Avatar
Default Re: ABS Delete on 2001 ITR
Why do you want to remove it?
Jas9848's Avatar
get a proportioning valve from a 94-95 rs or a 99-00 si and bend and flare some lines yourself.
Old Feb 18, 2009 | 05:39 PM
lol, this question never stops, from the treads i saw. It comes down to preference. ABS is in my opinion for people that panic and cant react in a situation.
I also want a cleaner look, doing a wire tuck also. On the plus side a bit of weight reduction. Also i have JDM axles with no rings on them.
"Jas9848" Why such specific years and cars for the prop valve?
Thanks for the reply's guys
Old Feb 18, 2009 | 05:42 PM
Jas9848's Avatar
because both of the cars are non-abs and have rear disc brakes. they are both 4040 valves. and eg ex coupe with rear disc would work also, but some of them have abs. an abs prop valves only have 4 ports (they are split front/rear through the abs unit).
Old Feb 18, 2009 | 05:43 PM
That's good to know. Thanks
Old Feb 19, 2009 | 06:18 AM
black98gsr-t's Avatar
incorrect.... the prop valve for a 94-97 rs integra is diff... its like the ones on the 92-95 civics the lines will not match up right..... U need a prop valve from a 98+ integra rs or a 99-00 civic si.... those are the same part numbers.... as for the lines u need the 2 lines from the master cylinder and the 2 lines for the front wheels..... the rear are the same.... in all it was a pretty cheap and easy mod... i've done 2 integras... sux that the search wont bring up the ABS delete thread in the integra section..... there are plenty of good pics to show..... and also the part numbers u need....
Old Feb 19, 2009 | 12:04 PM
floatfisher's Avatar
are people that dumb where they think removing ABS will make them go quicker?? Stop eating for a few weeks and your car will def move quicker
Old Feb 19, 2009 | 12:48 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
i dont think hes dumb because he wants to remove the abs... its actually a good mod for road racing... i personally don't like abs..
Old Feb 19, 2009 | 01:19 PM
nsxtasy's Avatar
H-T Order of Merit
Apparently, they are indeed!
No, it isn't. In road racing, ABS doesn't detract from anything; in fact, it helps, as a learning aid as well as a safety mechanism. If you are really good at track driving, you know how to do "threshold braking", in which the brakes are just at the threshold of locking up without actually doing so. You won't actually get into the ABS unless you're doing something wrong, in which case it's a good way to learn how to execute threshold braking. Furthermore, if you get into a panic situation - and yes, this can happen in road racing, when the car whose bumper you're right behind does something unexpected - ABS can be a big help to maintain your steering ability. Even more so if the pavement is wet or the car ahead dumps fluid (which happens, on the track).
But it's your car; if you want to disconnect the ABS, go ahead. Charles Darwin would approve! Maybe one day you'll win one of his awards as a result!
Originally Posted by George Carlin
Just think how stupid the average person is, and then realize that half of them are even stupider!
Old Feb 19, 2009 | 01:38 PM
migs's Avatar
You need to source the prop valve from a 1998 Integra RS:
(1) 98 Integra RS prop valve
(4) All four front brake lines from a 98 Integra RS as well. It is all a factory fit.
Old Feb 19, 2009 | 02:00 PM
Lucky-R's Avatar
sadly this is the current culture now saturating the ITR forum on HT.
Old Feb 19, 2009 | 09:21 PM
mn_babyboy's Avatar
Great thread. I was going to remove mine. Building a SFWD type r. It's your R do what ever you want to it. Just don't go rice.
Old Feb 19, 2009 | 09:32 PM
ScottBell's Avatar
Nice Comp. White 01 ITR.
Personally I would leave the ABS.
Old Feb 19, 2009 | 09:58 PM
Don't take it out.
The Integra Type R's ABS system was envied by all the race teams. During its' time the ABS was one of the main reasons it did so well in real competion.
In all honesty you are devaluing your R. The ITR was the only car of its kind with a sophisticated ABS system in its class during its time in the late 90's.
The ABS system is a piece of Technology that helped make the R what it is.
Old Feb 19, 2009 | 11:54 PM
RagingAngel's Avatar
I wouldn't go so far as saying it would devalue the R.
It's not like he's cutting the whole car up and putting in a small/big block V8. Removing/reinstalling the ABS is just a matter of a weekend's worth of work...in short, completely reversible.
Old Feb 20, 2009 | 03:56 AM
sheekdude's Avatar
(1) 98 Integra RS prop valve or 99-00 civic si
Very well put, short and simple.
Again, very well put sir.
Old Feb 20, 2009 | 06:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
Don't take it out.
It's the same 4-channel ABS system that's found on all ABS integras from 98 to 01. Nothing special other than it was the only trim level to get 4-channel ABS in 97...
In fact, I think it's even the same system found on 99-00 Civics...
Old Feb 20, 2009 | 07:38 AM
RockinaRHard's Avatar
On track, I enjoy the ABS... threashold braking would never be the same
Old Feb 20, 2009 | 02:54 PM
Numba1 K Series's Avatar
Hi!
When I had my ITR, the ABS was absolutely positively amazing.
If it's for looks, then you don't deserve that car.
The whole wire tuck thing is cool, but I prefer my own safety rather than impressing a bunch of fanboys.
Old Feb 20, 2009 | 06:57 PM
ShawnR's Avatar
Agree!
OP - What intercooler is that?
Edit*
This is user RedCoupe.
Old Feb 20, 2009 | 10:33 PM
racebum's Avatar
same here. i have never understood abs removal or why people do it. if you're so good at braking standard you should never notice the abs being there. snow and ice racing is the only place i would not want abs.
Old Feb 24, 2009 | 09:52 PM
buddyclubteg's Avatar
i remember seeing a a few cars on here that had abs and a very clean wire tuck.why not the best of both worlds
Old Feb 25, 2009 | 04:54 AM
legomytego's Avatar
^ he is going to drag the car not road race from the looks of it so what does he need abs for ? if he dosent need it y keep it .
Old Feb 25, 2009 | 06:22 AM
Redcoupe's Avatar
99-00 civics didn't have abs.
Originally Posted by ShawnR
Agree!
Edit*
Hey, thats me.
Well, I've never tracked a car but on the street, I'm glad I've had abs on numerous accounts.
