wheres the speedo cable
Old Feb 18, 2009 | 04:32 PM
Stiff_Crx's Avatar
Default wheres the speedo cable
ok so my friend having problems with his speedo cable and i dont exactly know where it is on an 02 accord is it in the same location as all the other hondas? cause everything on his car is completely stock and seems to be all cluttered and havent really seen a stock car like that in awhile so if anyone can please help me out
Old Feb 18, 2009 | 04:43 PM
92civlude's Avatar
Default Re: wheres the speedo cable
02 Accords dont have a speedo cable. The PCM interprets vehicle speed from the countershaft speed sensor on automatic trans cars. And from the VSS on manual trans cars. Also if there is a problem with the speed sensor, the Check engine light will come on and store a relative code. If the speedo head is faulty or wiring to the speedo head is open, the check engine light will not come on.
Old Feb 18, 2009 | 04:50 PM
Stiff_Crx's Avatar
where is the vss located? cause his car is a manual trans. and his check engine light is on.
Old Feb 18, 2009 | 05:05 PM
92civlude's Avatar
Its on top of the tranny (of course,) near the firewall below the throttle body intake hose. Right behind the shifter bracket. You will see a 3 pin connector The VSS is held on with 2 10 mm bolts
Old Feb 18, 2009 | 05:14 PM
Stiff_Crx's Avatar
Oh ok so it shouldn't be to hard to find thanks I appreciate the help
superslowcrx91
May 8, 2013 08:10 PM
f22kid
Apr 7, 2008 08:43 AM
TMC_EF
Jul 16, 2007 10:37 PM
EF9 JAMS!!!
Mar 26, 2006 01:27 PM
dirtracer
Feb 9, 2005 06:36 AM
