Retro Integra
I was in the market for some hid's.. which i was going to buy some cheap ebay one's.. but before i do things.. i research before i buy anything... so hear i am.. how do i do the retro hid in my 95 integra.usdm lights.. that is what i am trying to figure out.. could somebody telll what i need to buy.. or where i can buy a kit... i know that i need some type of projector.. but i don't really know what is up.. thanks.. a lot. i am a noob when it comes to retro hid stuff// thanks again..
Simple, register at HIDplanet's forums, and then go here:
http://www.hidplanet.com/forums/view...=135535#135535
There's about 8 DIY threads with the required supplies.
Before buying ebay projectors, go on ebay and search for any of these, they will all fit integra housings:
Valeo DOT D2S (Audi A4)
Hella Single Xenon (Audi A6)
Hella Bi-Xenon (RS6/A6)
Bosch Bi-Xenon (E46)
Bosch Single Xenon (E46)
Infinity FX35/45 Bi-Xenon (FX)
Infinity G35 Bi-Xenon
Stanley Low Beam (TSX)
Hella 2ND Gen Bi-Xenon (E55)
Hella Single Xenon (E55)
Hella Single Xenon (E39/X5)
RX330 AFS Projectors
RX330 None AFS
S2K Projectors
Some of them will run you upwards of 100 per projector, but others will sell for less than 50 bucks. Just stay away from the hid stores which have extreme markup. If you watch ebay over the course of maybe 2 weeks you could find a good deal on the cheaper projectors.
RX330 None AFS
S2K Projectors
i know that you reuse your stock headlights.. cool i am going to get the e55 projectors and and what ballast and light bulb do i use?? i guess the same exact one.. that e55 uses or what??
You can also purchase aftermarket ballasts, but I would probably stick with those with a good warranty. Search for DDM, they make decent ballasts for super cheap.
As for bulbs, do not run anything other than OEM philips bulbs. Aftermarket bulbs are crap in terms of output and they put out a lot of heat which will destroy your projectors.
Nope, you can use whatever ballast you want. You can go OEM Acura/Nissan/Lexus/Audi/MB/BMW, whatever, it doesn't matter. Oem ballasts will probably run you about 100 for the pair.
It makes everything go smoother if you get a 2nd pair of headlights. Gives you time to do things correctly and not rush. Integra lights are one of the easier lights to do. Plenty of people have done them. Look up Dark Angel on Hidplanet, hes got lots of pictures and he has no problem offering advice.
