Jb weld radiator question!!!
Old Feb 18, 2009 | 02:02 PM
wdissident's Avatar
Default Jb weld radiator question!!!
so my top bracket that goes from the bumper to my radiator is cracked. im in a financial crisis and cant afford a new radiator. will JB WELD hold? i have people saying it wont and some saying it will. thanks
Old Feb 18, 2009 | 03:04 PM
non-VTEC's Avatar
Default Re: Jb weld radiator question!!!
wont hold for long......tried it before.......
Old Feb 18, 2009 | 03:12 PM
1grex's Avatar
x2 it won't work
Old Feb 18, 2009 | 04:53 PM
wdissident's Avatar
how long is not long?...
Old Feb 18, 2009 | 07:07 PM
srmofo's Avatar
ninja edit ...reading owns me
Old Feb 18, 2009 | 10:07 PM
dcvt16's Avatar
if you clean it up real well it should hold for a while. back in the day i did it and it lasted almost a year.
Old Feb 18, 2009 | 10:28 PM
RedneckRicer's Avatar
try mighty putty.. Billy Mays swears it can do anything.. LMAO
Old Feb 19, 2009 | 05:29 AM
srmofo's Avatar
yeah its even in the commercial
NSFW... http://break.com/index/alternate-mig...chid=?matchid= ...NSFW
Old Feb 19, 2009 | 06:34 AM
1grex's Avatar
When I tried it it failed immediately
Old Feb 19, 2009 | 06:59 AM
fcm's Avatar
fcm
Old Fart
JB Weld is pretty good stuff and if you clean the surface real good, [no dirt, paint or moisture] use proper portions, [equal amounts] and mix well in room temperature and apply on rad that is also at room temperature and let sit, at room temperature, for 24 hr, it will hold . 94
PS, how long it will hold will depend on how well you do the job, however it is not a permanent repair and it will fail, your trying to fix something that vibrates, switches between real cold and real hot, [expanding and contracting] is under pressure and has moisture, [hot moisture under pressure with vibration] if it holds for 6 mo. your doing good, if it holds for a year, run out and buy lottery tickets before your luck runs out.
Old Feb 19, 2009 | 07:57 AM
dcvt16's Avatar
Originally Posted by fcm
JB Weld is pretty good stuff and if you clean the surface real good, [no dirt, paint or moisture] use proper portions, [equal amounts] and mix well in room temperature and apply on rad that is also at room temperature andlet sit, at room temperature, for 24 hr, it will hold . 94
yes.
wdissident
Welding / Fabrication
Feb 18, 2009 07:05 PM
wdissident
Feb 18, 2009 05:00 PM
yz125rider21
15
Jan 7, 2008 11:42 PM
NuclearB18B
Sep 30, 2003 01:44 PM
mikecel79
Jul 24, 2001 10:10 PM
