Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tensioner bolt recall on R-18 engine
Old Feb 18, 2009 | 01:03 PM
guinnessstout's Avatar
Icon2 Tensioner bolt recall on R-18 engine
Has anyone had this done yet?
Does anyone have a print of the actual recall from honda w/ the labor steps and times?
Old Feb 18, 2009 | 01:52 PM
baastard's Avatar
Default Re: Tensioner bolt recall on R-18 engine
this the first recall? i got the first recall done. i thought it was sometimes simple like an O-ring or something tho
Old Feb 18, 2009 | 03:12 PM
safedriver's Avatar
I got "Safety Recall: ABS Wheel Sensor O-Ring Inspection" for my Civic 06 EX sedan. the wheel sensor may not have been installed properlyand do not seal the hub assemble. Moisture could cause the wheel bearing to corrode and may cause the wheel to separate and fall off (like most Dodge cars and trucks).
I got another "Product Update: Rerouting the Drive Belt" also for my 06 EX Sedan. This is the Auto-Tensioner Pivot Bolt, that can cause engine noise or a loss of power steering.
There is no recall number on my letters, however, there is a Honda Automobile Customer Service number (800) 999-1009
I plan to get my car fixed, before the wheels fall off in a turn that I can not steer through.
Old Feb 18, 2009 | 04:15 PM
spooge24's Avatar
My 06 LX was built in early Feb 06. I had the dealer check my O-rings and they said they were fine. Every time I go there I always ask if there are any new recalls and they always tell me none that apply to my car that haven't been taken care of.
Old Feb 18, 2009 | 04:20 PM
Jas9848's Avatar
there are a few recalls out for 06-up civics
first there was the water pump bolts come loose--had to replaced water pump pulley and bolts
then there was the water pump, pulley, bolts, and belt replacement
and now there is the belt tensioner bolt and belt replacement
honda has gotten a little ridiculous with their recalls lately...i don't know what happened to their quality control.
Old Feb 19, 2009 | 09:17 AM
I had it performed this morning, The recal number is 09-007. They put a new belt tensioner pivot bolt and also put a new drive belt on. They said that the pivot bolt head was breaking off and causing damage so they changed it and gave me a new belt. I have 49k on my 2006 Ex 4dr. It only affects 2006 civic 2dr/4dr and the GX models. It only took about 1.0 hr at dealer. The recall came out on Jan. 30, 2009.
Old Feb 19, 2009 | 09:24 AM
spooge24's Avatar
Just got the "Product Update" today. Maybe this will take care of the slight vibration noise at low rpm...
Old Feb 19, 2009 | 10:46 AM
The update didn't help with my idle vibration issue. I talked to a tech at the dealer and they said that a Valve adjustment will calm the idle vibration. They have been finding tight valves and idle issues related to valve clearances being tight.
Old Feb 19, 2009 | 11:03 AM
spooge24's Avatar
Colud the valve issue be the reason why the idle dips below 500 rpm periodically? Feels like its going to stall, then it kicks back up to about 600 rpm after a second or two... does it in gear and in park.
Old Feb 19, 2009 | 11:42 AM
postman's Avatar
id reccomend if this recall aplies to you get it done. we just had one of the bolt heads break off at our dealer. had to put a new block in it. honda overtightened the bolts from factory causing them to strech to much.
Old Feb 20, 2009 | 10:41 AM
I'm not sure if the valve adjustment will help a hunting idle but it will smooth things out from a vibration point of view. Some of my friends cars have that issue of falling idle only when the a/c turns on, fans turn on , or there is a load put on the electrical system.
Maybe one of the more senior techs on here would have more knowledge than me.
Old Feb 20, 2009 | 04:49 PM
postman's Avatar
could have eld issues. depending on eclectrical load
Old Feb 24, 2009 | 03:18 AM
killa rex's Avatar
I'm getting this recall done on Wednesday, along with the wheel bearing/abs recall too....
Old Feb 24, 2009 | 07:57 AM
mikeunreal2's Avatar
I have an 06 sedan, how do I know if any of these recalls are an issue. I have a rough idle and sometimes I hear a loud ticking noise, but I am not sure if any of this is associated to any of the recalls. Should I get a letter or something if there is a recall that needs to be fixed?
kine462's Avatar
Just wait till the bolt snaps and u can't get the threads left out of the block!!!!!! New motor time!!
Old Feb 24, 2009 | 07:58 AM
kine462's Avatar
Originally Posted by postman
could have eld issues. Depending on eclectrical load
eld normal operation includes dimming or flickering of dash lights sorry for the caps lock, we use and adp system at our dealership
Old Feb 24, 2009 | 12:33 PM
spooge24's Avatar
I just got the tensioner and belt replaced today. I was in and out in about 45 minutes.
Old Feb 25, 2009 | 09:11 AM
Call the dealer and give them your VIN# they will be able to tell you if the recall is for your car.
I would not wait until the bolt head breaks, The amount of time that it takes for them to get a new block and re-build the motor and install it is too long for me. They give you a surp. belt also why not get a free wear item that would need replacing at around 100k miles any way.
johnlvs2run
Oct 20, 2011 12:28 PM
s4play
Aug 6, 2009 06:47 AM
fireslave
Apr 14, 2009 12:27 PM
SETI20
Feb 28, 2006 06:01 AM
dacaveman
Sep 1, 2003 07:32 AM
