ef sidemarker question (searched)
really quick, can i have my sidemarkers stay on with the corner lights, but ALSO blink with the corner lights? like a combination light? has anyone ever done this?
google worked for these
http://www.geocities.com/bracecraig/...e.html#cornerc
http://www.danielsternlighting.com/t...rkerflash.html
I'm sure there are more out there on google.
mines connected to my corner light. theres 2 socket. parking light and a signal as well (which also stays on) mine stays on and blinks when signaling
signal, cause it turns on and stay on, then when you signal it will start to blink as well. its the socket away from the headlight..(the orange part not clear)
on your corner light. it has socket that stays just on, and another that stays on a blink.
the one that stays on and blink has 3 wires. black=ground red=constant green=blink.
the one that just stays on has 2 wires. black=ground red=constant [might be a different color]
and you have the one blinker on your bumper which just blinks and doesnt stay on.
this is how my crx is setup.
so if you want it to stay on and blink i would splice it to a constant and a blink.
the black wire on your sidemarker being constant.
double positive is what its called.
Sorry, we were unable to fulfill your request
Reason: Your search returned a null resultset
Possible Causes:
thats some of the error that comes up.
Possible Causes:
http://www.tuner-junction.com/TJForu...html#post46773
ok if the web site dnt work its under civic crx facts in the sticky above . it says JDM crx sidemarker something
theres 2 plugs to a box for the belts behind the center console on the floor. (brown and green plugs if i remember correctly) there are also 1 plug under each seat. and the fuses are located on the positive terminal on the battery. 2 30amp fuses (green)
thanks for the info on the belts. I'll give that a shot tomorrow. i was able to check out the side marker install and i will cut the holes tomorrow. Mine should arrive on monday so hopefully monday night i can just snap em in and wire em up.
The dudes wiring on the tutorial was weird. either way, how do the real JDM ef's have them? always on AND blink, or just blink? similar to BMW, they arent on all the time.
B16CRXVTEC
Mar 8, 2010 11:11 AM
