Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 V6 Accord 60k Service questions?
Old Feb 18, 2009 | 09:24 AM
Matt00's Avatar
Default 04 V6 Accord 60k Service questions?
Hi guys,
I just hit 60k on my V6 6spd accord. Dealer A said it would be $399 and its basically checking everything, tire rotation, and oil change. Dealer B said it will be $799 and they adjust the valves, change trans fluid, numerous checks, change fuel filter, oil change and tire rotation.
Is it normal for them to do valve adjustments? Is it necessary? What do you guys think?
Old Feb 18, 2009 | 12:04 PM
BMaDOHC's Avatar
Default Re: 04 V6 Accord 60k Service questions?
I work at a dealer and never have heard of a valve adj at 60k on newer models unless there is an issue with loud valves or a misfire concern. sounds like a scam.
dont do the service at all in my opinion. go there get an oil change, tranny service, and a tire rotation if you even need it, you can check yourself it you need a rotation. also its a good idea to get an air filter and cabin filter which is easy to do yourself and save hundreds of dollars
Slow&Steady
Honda Accord (2013 - 2015)
21
Aug 16, 2019 12:55 PM
curvenut
Jan 11, 2013 07:35 PM
o8EXLCoupe
Jun 3, 2008 06:30 AM
hometheaterman
Jan 30, 2008 03:44 PM
phandovan
Feb 5, 2007 11:06 PM
