GSR Calipers/Rotors on CRX SI hubs?
Old Feb 18, 2009 | 09:20 AM
KidFrost's Avatar
Default GSR Calipers/Rotors on CRX SI hubs?
Ok I have looked and looked, and I cannot find the awnser to this. I dont think you can directly bolt gsr calipers and rotors on crx si hubs but is there some sort of kit so this is a bolt on affair.
This has been covered before I am sure of it but I have spent quite a bit of time searching to no avail, so if there is a link plz post it.
Old Feb 18, 2009 | 09:49 AM
EL Vap133's Avatar
Default Re: GSR Calipers/Rotors on CRX SI hubs?
No, you cannot directly bolt them onto your CRX knuckles. You would have to modify them (grinding, etc) or you can use either 90-91 Civic EX knuckles or 90-93 Integra knuckles.
Old Feb 18, 2009 | 10:09 AM
KidFrost's Avatar
but in my research its been said the da knuckles give you camber problems on a crx or in my case a civic w/ crx knuckles
also what kind of modifing is needed .. to what extent? is there a how to?
Old Feb 18, 2009 | 10:23 AM
EL Vap133's Avatar
I have the 91 Integra knuckles on my CRX using the 96 GSR brake components and have had no problems. Check this link out:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/da-knuckles-vs-si-knuckles-ex-knuckles-big-brakes-2140287/
Also, check the FAQ at the top of this forum under the "Suspension/Brake" category.
Old Feb 18, 2009 | 12:32 PM
93civiceg6's Avatar
A buddy of my have a set of 90 91 ex knuckles he might not need he sold his crx let me know
Old Feb 18, 2009 | 12:41 PM
EFstyle's Avatar
I wouldnt call them "problems". DA knuckles are not as good as EX knuckles on our civics and CRX's because the goemetry isnt EXACTILY perfect on our chassis, but with an allignment, you'll be perfectly fine with the DA knuckles
Old Feb 18, 2009 | 12:44 PM
slow88si's Avatar
the only problem i had with 90-91 da knuckles is the tie rod mount is lower, fixed with an alignment
Old Feb 18, 2009 | 01:07 PM
KidFrost's Avatar
ok i realize with alignment i can get da knuckles will work but ithat isnt what i was looking for.
as the title states what is needed or needed to be done to get GSR calipers to bolt to crx si hubs. Is there some sort of adapter plate needed? one person said some modifing(grinding ect...) is needed ...like what ?
Old Feb 18, 2009 | 01:55 PM
EL Vap133's Avatar
Have you checked the FAQ yet?
I did and I found this: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-brake-upgrade-integra-front-brakes-dx-knuckles-1484555/
Old Feb 18, 2009 | 02:46 PM
KidFrost's Avatar
so all of the sudden if i own an ef i am supposed to look in the eg faq... ??
any way does the same apply to 91 crx si hubs. your link applys to 92+ DX hubs...
and yes i did search the faq's
Old Feb 18, 2009 | 03:01 PM
EL Vap133's Avatar
We have a search function you know.
Old Feb 18, 2009 | 05:45 PM
KidFrost's Avatar
thanks el vap but you are not helping at all.. i have searched.. as i stated earlier.
so no need for you to post here anymore.
any way bump!
Old Feb 18, 2009 | 06:03 PM
slow88si's Avatar
I spent 50 bucks on a complete set of da knuckles for mine to work and 30 on an alignment. Thats to hard to pass up its cheap and easy way to get the brakes working.
If you want to go the hard way it looks like trial and error for you, thats your best bet make them work and think down the road when you buy brake pads you'll have to modify them to fit, alot of work when you can spend 80 bucks and have it done in two hours.
Old Feb 19, 2009 | 11:10 AM
EL Vap133's Avatar
any way bump!
Ha ha ha how am I not helping? I just gave you a link that you need to do the conversion you need.
Old Feb 19, 2009 | 02:40 PM
88Hatchy's Avatar
bolt the DC2 calipers and rotors onto some DA knuckles, get an alignment and call it a day
schock3
May 26, 2009 02:03 PM
nihad
12
Nov 9, 2007 10:13 PM
91CR-XSiR
Jul 25, 2007 11:03 AM
red civic standard
Oct 21, 2002 11:25 AM
