Is it possible to use a '92 Canadian prelude SR tranny with a 2001 H22A longblock
Old Aug 9, 2002 | 04:07 PM
canuck-mx6's Avatar
Default Is it possible to use a '92 Canadian prelude SR tranny with a 2001 H22A longblock
My friend blew his motor H23 and he is picking up a 2001 long block H22A. The problem is that the long block came with an automatic tranny. Will his tranny from his orginal motor bolt on without any problems?
Also, are the engine mounts the same between the h22 and the h32?
Old Aug 9, 2002 | 06:40 PM
satan_srv's Avatar
Default Re: Is it possible to use a '92 Canadian prelude SR tranny with a 2001 H22A longblock (canuck-mx6)
Engine mounts are the same, and the H23 should bolt right up. You won't have the best gearing, but it will work fine. Correct me if I'm wrong.
Canadian Trannies are the same as their respective US trannies
Old Aug 10, 2002 | 04:41 AM
canuck-mx6's Avatar
Default Re: Is it possible to use a '92 Canadian prelude SR tranny with a 2001 H22A longblock (satan_srv)
Cool, what about the harness, I know that he will need the plug for the VTEC solenoid, is there anything else, or can he use his existing harness, and a VTEC ECU
Old Aug 10, 2002 | 07:04 AM
ViZ's Avatar
ViZ
dont forget to hook up the little pink wire going to the runners.. and the h23 trans will bolt up just fine, there are a few other things thatyou should take into consideration and i would do a search to clarify.. if you go to hondaprelude.com on there main page there is a write up to do teh h23-h22 swap but i dont think they tell you to hook up the runners...
ViZ
H22Abeast
Mar 30, 2009 08:14 AM
accord93racer
Feb 21, 2006 05:33 AM
veganej
Apr 12, 2005 08:54 PM
JBB194
Jun 12, 2003 08:15 AM
tonylude94
Dec 10, 2002 04:01 PM
