Brakes, Power Steering, AC
Old Feb 18, 2009 | 08:56 AM
Canadian_EF's Avatar
Default Brakes, Power Steering, AC
Okay, I have a few questions in this thread.
1. What larger brakes could I drop into my CX Hatchback? Will I have to change the axles?
2. If I get a B16 engine, will I have to get the power steering bracket/pump and the AC bracket/pump that goes with it? Or can I use the ones that I already have mounted?
3. In a list form, or a chart or something if someone has made one, what rear trailing arms are a perfect swap for the CX hatchback? Are they hard to get a hold of?
Many thanks...
Old Feb 18, 2009 | 10:30 AM
KidFrost's Avatar
Default Re: Brakes, Power Steering, AC
1. SEARCH!! Searching = instant results. Let me help you.. https://honda-tech.com/search.php
2. cx hatch was never made in the 88-91 civics so you either do not know what kind of car you own OR you are in the wrong forum.
Old Feb 18, 2009 | 10:32 AM
In canada, the low end model is called the CX
and i searched, but did not find results.
Old Feb 18, 2009 | 10:39 AM
KidFrost's Avatar
i doubt you searched one search in 2 minutes gave me this info
https://honda-tech.com/search.php?do=process
https://honda-tech.com/forums/showth...grade+brake+dx
first question will be awnsered in any of the above links just read .. put some effort to finding knowledge you will learn alot more that way trust me.
No VDUBS here in206
Dec 3, 2008 03:54 PM
meagainsttheworld
16
Apr 11, 2006 06:04 AM
mooseknuckle
12
Jan 3, 2002 02:20 PM
Lookincrazy
15
Nov 27, 2001 08:13 PM
