FS: Dx/STD conversion harness OBD1
Old Feb 17, 2009 | 08:15 PM
Didly's Avatar
Default FS: Dx/STD conversion harness OBD1
UPDATE 02/17/09
Harness is for an EF forgot to put that in the title!
PLEASE DO NOT PM ME UNLESS YOU'VE BUMPED THIS THREAD!!!!!!!!
I have forsale a engine harness to convert your DX/STD 89-91 crx or civic car to run OBD1 vtec... So (D15b... d16z6 ZCVTEC D16A vtec...)
also... if you are running a chipped ecu you can run this harness with a gsr prolly all b-series Just let me know if your interested and I can double check.
It will run with a p72 but you will need knock and IAB's... rywire will do this for 50 bucks!
Okai so my friend sold his DX crx shell and took some parts out 1st...
Crx DX- SOHC VTEC... (d15b z6 or zcvtec) Rywire jumper harness
As well as the entire Engine harness already hooked up for vtec...
the harness was sent in to rywire about a yearish ago.
Looking for like 250[B/] picked up
Cost 300 plus down time from rywire PLUS you need an SI harness I believe as well as your stock harness
Please review this before you think about buying this harness..
[b]I WILL NOT BE RESPONSIBLE IF YOU BUY THIS AND ITS FOR THE WRONG CAR OR MOTOR PLEASE READ THIS CAREFULLY
http://rywire.com/store/8891-c...31ba7
PICS are of the Jumper harness only..Itcomes with the JUMPER HARNESS as well as the complete ENGINE HARNESS...
100% plug and play just run obd1 injectors and ditch the resistor box and your set!!
If you want more pics or pics of the engine harness JUST ASK!!!
Old Feb 19, 2009 | 11:24 AM
Didly's Avatar
Default Re: FS: Dx/STD conversion harness OBD1
Ttt
Old Feb 20, 2009 | 10:09 AM
Didly's Avatar
ttt
Old Feb 22, 2009 | 07:25 PM
Didly's Avatar
Bump
Old Mar 10, 2009 | 04:10 AM
i heart honda's Avatar
bump
shocker911
May 14, 2010 02:29 PM
Didly
Nov 12, 2008 09:24 PM
IHEARTMYHONDA91
Aug 4, 2008 04:45 PM
4gencivicef9
12
Jul 31, 2006 05:30 PM
