need help removing/installing cam gear for b16
Old Feb 17, 2009 | 07:58 PM
nengx07's Avatar
Default need help removing/installing cam gear for b16
ok i got a leak on my cam gear seal right by the cam gear.. is there anyone who can help or have link to a thread to how to remove cam gear and install the cam gear back in???? please help H-T!!! car will be done after this installation
Old Feb 17, 2009 | 08:27 PM
nengx07's Avatar
Default Re: need help removing/installing cam gear for b16
bump.. anyone??? cmon theres gotta be someone who knows how to remove/install cam gears
Old Feb 17, 2009 | 09:14 PM
nengx07's Avatar
bump bump.. need a clue.. searched everywhere on google also but nothing.. need to know TONIGHT so i can dream about fixing it and actually do it tomorrow morning..
Old Feb 17, 2009 | 09:19 PM
jgraham0326's Avatar
Well hopefully your car is in time, and if so then make sure the #1 piston is TDC then i would zip tie the timing belt to the cam gear then proceed to remove the came gear and replace the seal. The biggest thing is to not have your timing belt slip cause you do NOT want to knock the car out of time or you will have a new set of issues. hope this helps some.
Old Feb 17, 2009 | 09:21 PM
nengx07's Avatar
ok thx.. should i use regular wrench to take it out or just use impact gun to take it out in 2 secs??? any more ideas HT??
Old Feb 17, 2009 | 09:26 PM
regular wrench for sure and get the proper torque spec for when you re-install it as well.
Old Feb 17, 2009 | 09:28 PM
nengx07's Avatar
Cam gear bolts - 41 ft/lbs.. is that true?? got it from a site but it didnt show how to install/remove..
Old Feb 17, 2009 | 09:33 PM
what motor is it exactly?
Old Feb 17, 2009 | 09:35 PM
nengx07's Avatar
b20V.. b20b block with b16 head..
nengx07's Avatar
head is a 00 si head
Old Feb 18, 2009 | 01:42 PM
nengx07's Avatar
ok i have an aftermarket crank pulley that doesnt show my TDC mark... how will i know when its at TDC????
Old Feb 18, 2009 | 03:21 PM
Place a rod through the spark plug hole onto the piston and rotate the engine until the piston is at TDC. This can be done by eye but a dial gauge is preferable for accuracy.
Once TDC is established the marks on the cam gears should line up. Note that the marks when lined up may not be horizontal, but angled slightly. To confirm the cam gears are correct a ruler may be placed across the width of both cam gears so that all 4 marks line up and the rule is over the centre of the cam gear retaining bolts.
this came from a tuning guide I have.
Old Feb 18, 2009 | 03:26 PM
Unseen Racer's Avatar
forgot to mention that the piston has to be in its highest point and the intake valve has to be up.
cuz it can be up and the exhaust valve can be up.
so its place long rod/screw driver inside spark plug hole, turn till piston is on its highest point AND intake valve is up
Old Feb 19, 2009 | 07:15 PM
nengx07's Avatar
so number 2 and 3 pistons have to be up at highest point if im correct???
Old Feb 19, 2009 | 08:11 PM
no. piston 1 (the one NEXT to your timing belt) needs to be at its highest point AND the intake valve (the 2 valves that are towards your windshield) have to be up. piston #4 (piston NEXT to your intake pipping) will be up as well EXCEPT the exhaust valve will be up and the intake valves will be down.
SO piston 1 ALL the way up and intake valve OPEN. which will cause PISTON 4 to be UP as well and exhaust valve will be open. its easier to see the valves if you take off your valve cover
Old Feb 19, 2009 | 08:14 PM
nengx07's Avatar
ok i will be doing it tomorrow after work.. seems like removing the cam gear is alot harder then putting a new head on LOL.. less info thats y..
Old Feb 19, 2009 | 10:18 PM
lol. no problem. just make sure on your life that you do not move ANYTHING that will mess up the timing cuz then its a B*** to get it back.
and if you do not have the helms manual or a tourque wrench, i suggest buying them. they come in REAL handy.
donny D
May 26, 2017 07:03 AM
jdm27ef
May 29, 2009 02:52 PM
Cuong-nutz
May 16, 2005 03:55 PM
b18-c-rx
12
Nov 13, 2004 06:11 PM
REDBARON
Feb 26, 2002 11:12 AM
